August 29, 2026, 02:05:58 pm
Hoffman Amps Forum image Author Topic: ToreVibe question  (Read 4334 times)
Offline Gone_Fishing
ToreVibe question
« on: June 30, 2016, 03:34:41 pm »
Completed my ToreVibe but it has 2 problems  (1) the higher you turn the Intensity, there is less gain/volume and it distorts (2) there is no fine adjustment on the Mix, that is, when it is turned up to about 2, the mix is already too much. I put in a 100K pot, but no cigar.  I built the ReVibe which was a lot more complicated but it is perfect. I have checked the wiring with Tore's schematic countless times and I can't see a problem. Tried different pans, tubes, etc.  Any help will be greatly appreciated. Thanks in advance.
Re: ToreVibe question
« Reply #1 on: June 30, 2016, 03:44:23 pm »
Always a good idea to link to the schematic & layout so folks know what you're working on.
Was this built from a Weber kit, and are the above linked docs correct?
