August 29, 2026, 02:04:21 pm
Hoffman Amps Forum image Author Topic: Marshall Plexi 1987 Hum and Chirping Noise problem every since changed the PT  (Read 5040 times)
Offline Kitarist
So the PT on this amp blew and i changed it with a new one. While the amp works and plays there are 2 types of noises coming from the amp.
The first one is coming from amp like a buzz hum noise while second noise is actually coming inside the amp its a weird chirping noise.
I'm not sure what could it be. I'm suspecting some filter caps got damaged but i'll  replace that also and keep you updated.
I alredy changed the rectifier dioes,tubes.
I was also suspecting the larmar PPIMV i changed the amp to stock and the problem was still present.
Here is also a video i made if anyone cares to take a look at it :)
« Last Edit: July 05, 2016, 11:42:07 pm by Kitarist »
Reverse the OT plate leads. Does that help?
Offline Kitarist
Sorry it was the PT made a typo ;)
I already checked heater polarity and so on...
Offline hesamadman
That chirping sounds more like arcing. Does the new PT have a center tap for the the 6.3vac?
