August 29, 2026, 02:05:23 pm
Hoffman Amps Forum image Author Topic: Hoffman grounding scheme question.  (Read 4565 times)
Offline labb
« on: July 10, 2016, 08:28:28 am »
Looking at the Hoffman grounding drawing...Where does the buss that goes down the back of the pots and  the pre amp grounds, the input jacks and the pre amp e-caps connect to attach to a  ground lug.
Re: Hoffman grounding scheme question.
« Reply #1 on: July 10, 2016, 08:40:08 am »
There's not a separate wire that connects to chassis. The input jacks provide a good chassis ground for that buss. In fact, if you solder that buss to the back of the pots like Hoffman does, then each pot body also provides a chassis ground connection.
Offline labb
« Reply #2 on: July 10, 2016, 08:51:41 am »
Thanks Sluckey. That is what I thought but just need a little hand holding. I ground mostly the same way except that I run a bus wire (not attached to the back of the pots) and ground it on a lug right at the input jacks. Other thing that I do is ground the mains on a lug by its self...By the way, Hope you know that us amateurs really appreciate having folks like you to bail us out when we really mess things up.
« Reply #3 on: July 10, 2016, 09:08:43 am »
That's exactly what I do also.
