September 15, 2026, 10:00:46 am
Hoffman Amps Forum image Author Topic: Fuse holder wiring  (Read 5224 times)
Offline labb
Fuse holder wiring
« on: July 24, 2016, 09:30:14 am »
Simple question. What is the correct way to connect a panel mount fuse holder...There is usually a terminal on the side and one on the bottom...Which terminal do you connect the lead from the switch to.
Offline vibrolax
Re: Fuse holder wiring
« Reply #1 on: July 24, 2016, 09:44:10 am »
Line (hot) is wired to the end terminal.  Switch (load) is wired to the side terminal.
Jon
