September 16, 2026, 12:34:16 pm
Hoffman Amps Forum image Author Topic: Physically smaller pots?  (Read 5690 times)
Offline hesamadman
« on: July 30, 2016, 07:48:09 pm »
I've been converting my 30 watt design to two channel for some time now. One thing that I think would benefit my layout is if I could replace the gain and master pot (1m) to a smaller pot. Does anyone know where I can get smaller sized pots?
Re: Physically smaller pots?
« Reply #1 on: July 31, 2016, 05:56:15 am »
Smaller sized .... do you mean 16mm pots ?
usually guys try to use 24mm pots instead of smaller ones
Have you space problems ?
In which side of the pond are you ? (USA - Europe - Australia ....)
http://www.tubes.it/alpha_main_ita.htm
http://www.tube-town.net/ttstore/Potentiometer:::50.html
« Last Edit: July 31, 2016, 06:03:14 am by kagliostro »
Offline hesamadman
« Reply #2 on: July 31, 2016, 06:34:43 am »
Thanks K. Yes 16 mm looks perfect. Only values I would need are 1m and maybe 500k. Looks like those are easily accessible. I am having a slight space issue on my two channel.
« Reply #3 on: July 31, 2016, 10:09:18 am »
K - those split shaft alpha 16mm in your second link are probably for guitars. These are the ones he wants. 1/4 shaft and 500V rating.
http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=PPP&Category_Code=Pot16
well I see they may have the same rating - just different style shafts...
« Last Edit: July 31, 2016, 10:16:42 am by mresistor »
Offline hesamadman
« Reply #4 on: July 31, 2016, 10:16:36 am »
Thanks MRESISTOR, I just ordered a few from your link.
« Reply #5 on: July 31, 2016, 10:34:23 am »
Often the knob and fingers limit how close we can space pots.
I do remember a discrete sequencer with 4*10 knobs in about 2"*4", but it was very hard to twiddle.
Offline hesamadman
« Reply #6 on: July 31, 2016, 12:15:46 pm »
I already have the pots installed and spaced well. But internally i have them sideways because the gain and master are laid out vertically rather than side by side. I would have a little bit of cleaner wiring if I didn't have to have the pots sideways.
« Reply #7 on: July 31, 2016, 12:44:16 pm »
Nothing wrong with mounting the pots sideways... Once the wiring is done and the amp is buttoned up, no one sees them.
« Reply #8 on: July 31, 2016, 02:26:43 pm »
+1 for HotBluePlates
Offline hesamadman
« Reply #9 on: August 02, 2016, 07:38:18 am »
Though not necessarily a huge issue, a smaller pot would just make everything a little easier. I have channel one on left and channel 2 on right. I also have LED indicators that illuminate on each channel separately. Heres my faceplate layout:
BASS- MID- TREBLE- (GAIN/MV stacked vertically) - <--LED-- Switch--- LED --> (GAIN/MV stacked vertically)- TREBLE- MID- Bass
The second channel is laid out as a mirrored image of the first. The LED's are a bit close to the (GAIN/MV stacked vertically) pots. If I had smaller pots, I could make this work a little cleaner.
Is there any difference in the function of these 16mm pots?
« Reply #10 on: August 02, 2016, 07:45:10 am »
no
