September 17, 2026, 09:42:03 am
Hoffman Amps Forum image Author Topic: LCR's in Hoffman 18 w Marshall  (Read 4421 times)
Offline Oddvar
« on: August 04, 2016, 06:04:25 am »
Hi.
In the build layout for Hoffman stout there are three 500 v 20uf electrolytics and one 40 uf 500 volt .
I was wondering if I could substitute thes four with two 50x50 uf 500volts?
Best.
Re: LCR's in Hoffman 18 w Marshall
« Reply #1 on: August 04, 2016, 07:23:42 am »
I would not use 50µF for the first cap seen by a 5Y3. But if you use silicon diodes it will be fine.
Offline Oddvar
« Reply #2 on: August 04, 2016, 07:55:35 am »
Wher should I put those?
« Reply #3 on: August 04, 2016, 08:10:25 am »
Oddvar,
It sounds like you are wanting to have only two filter cap stages of 50uf/500v instead of the four filter cap stages of the 18w?
You will be much happier I think with four filter cap stages and have a much quieter amp.  I would stick with the original plan that Hoffman has posted.
http://el34world.com/projects/images/18WattStout_8.gif
« Reply #4 on: August 04, 2016, 08:12:50 am »
Replace the 5Y3 with diodes.
Offline Oddvar
« Reply #5 on: August 04, 2016, 08:13:43 am »
I'll stick to the original layout then...(Thanks again)
