September 17, 2026, 08:44:17 am
Hoffman Amps Forum image Author Topic: Tremolo bypass switch  (Read 4435 times)
Offline upnorth2
« on: August 04, 2016, 09:57:44 am »
I'm using a switch to bypass the trem circuit in a Deluxe Reverb. Just wondering the best way to eliminate the open circuit "pop" when reactivating the tremolo circuit with the switch. I don't think an inline resistor or a resistor across the switch would work in this case.
Thanks for any input.
Re: Tremolo bypass switch
« Reply #1 on: August 04, 2016, 11:05:24 am »
When you say "bypass the trem" do you mean break the path for the INT pot to give a gain boost? Just put a 1M resistor across the switch. Easy to do. Might help with the pop.
And if this switch is a footswitch you'll need to use shielded cable.
