September 17, 2026, 10:53:06 am
Hoffman Amps Forum image Author Topic: Field Coil or Choke a SS replacement (schematic here)  (Read 5268 times)
« on: August 09, 2016, 01:37:13 pm »
I was looking for a Boosted LR8 PS schematic and I've find this circuit
the circuit actually is able to menage till 100mA but maybe someone here can suggest how increase the max allowable I
info on the pdf file
« Last Edit: August 09, 2016, 01:43:09 pm by kagliostro »
Offline drgonzonm
Re: Field Coil or Choke a SS replacement (schematic here)
« Reply #1 on: August 09, 2016, 02:20:15 pm »
I couldn't determine with a tube was a npn or pnp device, Basically, I am wondering if you replace that transistor with a tube.
I suspect you are probably better off working with mosfets.
