September 16, 2026, 08:31:21 pm
Hoffman Amps Forum image Author Topic: UX7 Sochet for Visio - I've draw one but I need help  (Read 4670 times)
« on: August 10, 2016, 01:44:34 pm »
I'm trying to draw an UX7 socket but I encounter some difficulties
1° I'm not able to have all the socket in white color
2° The mounting holes are different from the originals, not that I can't accept it, but which is the right way to draw such holes ?
3° I'm not able to design correct arc for the top and bottom borders of the sochet, so I used a big circle, how can I draw the correct arc and delete the big circle ?
Here the .vsd file http://www.mediafire.com/download/j82ld6a5d00e6e0/UX7_Socket.vsd the file is too big to be load on the forum (1.81MB)
Many Thanks for anu help and/or council
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: UX7 Sochet for Visio - I've draw one but I need help
« Reply #1 on: August 10, 2016, 02:35:59 pm »
for 2, to draw that type of hole, I'd think you need to draw two circles and connect them with lines and then group them? But I'm not great with visio, I've only played with it a bit.  Sluckey may know more, he's done a ton in visio.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #2 on: August 18, 2016, 07:40:08 am »
I played with this for a while but never got any closer than you have. But I can address your second issue...
Don't use an ellipse for the mounting holes. Use a rectangle instead. Make it the size you want. Then select "Line"--->"Line Options"--->Round corners.
« Reply #3 on: August 18, 2016, 08:45:41 am »
Many Many Thanks Steve
Now the holes are perfect !
I've read something about how tho create a close shape, but till now I wasn't able to realize it
so, till now, color problem persist (you can't fill something that isn't close to form a single object)
OK, I hope I can find a solution
Ciao
« Last Edit: August 18, 2016, 08:53:04 am by kagliostro »
