September 16, 2026, 03:17:06 am
Hoffman Amps Forum image Author Topic: Which Trem?  (Read 5876 times)
Which Trem?
« on: August 10, 2016, 04:18:52 pm »
Hi guys, Got another vintage Aussie amp on the bench.http://www.guitargear.net.au/discussion/index.php?topic=47211.0
It has had some mods done to it, mainly the TREMOLO.
I was wondering why it was changed from the original, is the LDR/Neon a better option compared to the original?
Re: Which Trem?
« Reply #1 on: August 10, 2016, 07:53:57 pm »
The low-level cathode injection thumps like a dog in the dryer.
(You or) The Designer drew it oddly. The double 0.022+470K C-R-C-R network "belongs" in the tremolated plate to reduce the thump.
LDRs arrived at the end of the 1950s. There was a fad to use them. In this case I would lean to the LDR because low-level cathode injection is never quite satisfying.
Re: Which Trem?
« Reply #2 on: August 10, 2016, 08:51:02 pm »
Thanks PRR, YEP connected to wrong cathode.
I'll leave trem wired as is and see what it sounds like when I get back together.
Re: Which Trem?
« Reply #3 on: August 27, 2016, 06:27:19 pm »
Hi guys, the new chassis have arrived, so I need to sort the trem.
The idea of the roach style trem is a stayer and I found the Maton SRG150 has the same trem as the Fender Tremolux. http://el34world.com/charts/Schematics/files/fender/Fender_Tremolux-AA763-schematic.pdf
I just need a bit of guidance on how it should be connected.
I'm thinking of connecting the intensity pot to single input3 channel as per sheet 4
I notice that the circuit also is connected to the bias supply, can that be deleted as there is no bias supply in this circuit.
« Last Edit: August 27, 2016, 07:07:30 pm by TIMBO »
Re: Which Trem?
« Reply #4 on: September 10, 2016, 06:09:38 am »
Hi guys, Completed wiring and got some nice sounds.
Voltages look good.
As PRR said thumping tremolo may be a problem and he was correct, it does work to a point but I think that other trem designs sound and work better.
I was going to use the LDR/NEON approach but this also was a bit beyond my knowledge to design.
The amp has an umbilical cord that connect the two chassis and there is an extra wire that can be used to convert it to a bias trem.
To do this I may need a bit of guidance on the trem circuit as most of circuits I have used only use one triode.
Re: Which Trem?
« Reply #5 on: September 25, 2016, 12:32:57 am »
Hi guys, I think I have nutted this trem out.
Using the LDR trem from Fender has worked well, with minor problems.
I'm using a 3M-RA for the speed that is providing a reasonable spread of speed, although it does not pickup much speed till full rotation and at full rotation the speed cuts out.
I don't have a 50k-RA intensity pot and using a normal 50ka, again the intensity only really kicks in till the last third of the rotation, will this improve with a 50k-RA pot.
Re: Which Trem?
« Reply #6 on: September 25, 2016, 10:46:46 am »
Yes.
Or try the straight audio taper, but swap the outside wires, and mark it 10-0. If that gives a good feel, except backward, buy the RA pot.
Re: Which Trem?
« Reply #7 on: September 25, 2016, 01:52:23 pm »
Re: Which Trem?
« Reply #8 on: September 25, 2016, 04:08:18 pm »
Build a reverse log pot if you need one
http://www.geofex.com/article_folders/potsecrets/potscret.htm
Ciao
Re: Which Trem?
« Reply #9 on: September 26, 2016, 04:58:48 pm »
> potscret.htm
Does not work except for straight potentiometer use.
The Fender LDR is wired different. The pad resistor will just kill signal.
There ARE reasons reverse-audio pots exist.
Re: Which Trem?
« Reply #10 on: September 27, 2016, 03:48:19 am »
Thanks PRR, New pot on the way.
