September 14, 2026, 11:20:01 pm
Hoffman Amps Forum image Author Topic: next - concept phase  (Read 4060 times)
« on: August 16, 2016, 12:15:25 pm »
Here’s the start, the finish is way beyond the horizon.
Working title, The Daddy 5.6.  One of the east coasts *top Ten* climbs and it’s in Dougs back yard, about 10miles up from Morganton NC, anyway;
Pre-Amp only…for now.  The concept is a salesmen demo, more choices than you need in a custom build.
I’m looking for, *tried and smiled*, member tweaked, sections I can, um, learn from.
V1 to V4, Or V1 1-4, I’m looking for something that *complements* a warm clean section.  That covers Ch1, the “normal” channel.
The Not-Normal channel is wide open, I’m looking for tested tone mods, like “notch”? filters, diode clipping, Good OD, etc.  I’ve *penciled in* the FireFlyVer3 mixed with the Reverend Knight V1 section, but I’ve already erased 2 pencils worth, ideas welcome.
I got the *usual suspects* down, I’m thinking of bending my own, making it tall enough to handle turret or eyelet boards mounted *vertical*, but if the *Teacher smiles* I am thinking, if the terminal strips are available, threaded rod with suspended T-strips, think W.W. backplane for tubes :icon_biggrin:. I’m starting with the Vox AC30C2 DC fil idea, KzooVer2 trem, something Fender Verb, 12 knobs, 3 jacks…….I welcome learning, even if it is tough love
Re: next - concept phase
« Reply #1 on: August 17, 2016, 09:46:03 am »
Here's the *NOR* channel.
The upper section is from my last build, and it meets my smiles test :laugh:, Warm, chimey, sparkly, clean,
the lower half is borrowed from Orange;
http://el34world.com/charts/Schematics/files/orange/orange_mkii1973.pdf
I did Xc calc's on the coupling caps (a 1st for me) and I come up with, (correctly?);
at 50HZ 47K for 330pF, and 22k for .0047uF
at 4KHZ 583 for 330pF, and 273 for .0047uF
my conclusion, this is attenuating the lows, passing the highs.
My question; why use a 47uF on V2a if you're gonna kill the lows?
and does this kill *too much* low?
Re: The Daddy
« Reply #2 on: September 05, 2016, 08:23:55 pm »
The working schematic below.  The borrowed line-up is;
NOIR
 a  RCA, PRR tweaked
  b Orange 1973
NotNor
 a Reverend Knight
  b Bogner estacy
Reverb PR  re-issue
Trem   Tim Hickey Moody Vibralux
New layout, standard *in-line*, probably tubes forward, 19”X ?, off the shelf blank chassis.
If there’s no glaring issues, it’s on to PS schematic.
Still under consideration;
Add a PI tranny as PreOut.  My thought is I would have 2, albeit outta phase, signals convenient.  Possibly used as differential driver?
Anyway, thanks for getting me this far.
