September 08, 2026, 12:17:52 pm
Hoffman Amps Forum image Author Topic: Tiesco Checkmate 88 distortion that is unwanted and reverb tweek  (Read 7738 times)
Offline TerryD
No doubt that this has very little power but I'm getting unwanted "mild and just a little" distortion at any volume from low to even lower.  Any advice on this old amp?
Also the reverb is very trebly...any fix for that?
Re: Tiesco Checkmate 88 distortion that is unwanted and reverb tweek
« Reply #1 on: August 16, 2016, 04:04:51 pm »
As I have never seen a Tiesco Teisco, a link to a schematic would help.
« Last Edit: August 17, 2016, 05:56:05 pm by PRR »
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #2 on: August 16, 2016, 04:29:11 pm »
Here's the one I can find:
http://s27.photobucket.com/user/irishronin/media/teisco88-a.jpg.html
not sure if that's the right one, but maybe?
~Phil
Phil Davis
tUber Nerd =|D
    • Daviszone
« Reply #3 on: August 16, 2016, 04:30:09 pm »
Also, as old as that amp is, have you checked the electrolytic capacitors?  Tubes are a first choice, though, but being that it's that old, it may need new caps.
~Phil
Phil Davis
tUber Nerd =|D
Offline TerryD
« Reply #4 on: August 16, 2016, 05:22:46 pm »
No, this is solid state.
    • Daviszone
« Reply #5 on: August 16, 2016, 06:37:14 pm »
Hmm then that schematic is wrong of course, being that it's a Teisco 88 tube amp.  Any schematic?  Sometimes it seems teisco put them on the inside panel?  If not, its going to be hard to troubleshoot.  It could be power filtering, like I mentioned, but I don't know if that impacts SS like it does tubes.  Otherwise it may have a Fet/mosfet that's going bad but I'm not great with SS myself.  Pics of the chassis if you don't have a schematic may help as well?
~phil
Phil Davis
tUber Nerd =|D
« Reply #6 on: August 17, 2016, 05:59:01 pm »
Amp of that age, working blind, full re-cap may be a path to try. At least all the small electrolytics. There's one or two BIG e-caps for the main power supply. They are past peak freshness but if they haven't leaked (yet), and there's no BIG buzz, you might leave them while tracing crap-signal problems.
