September 17, 2026, 04:13:00 pm
Hoffman Amps Forum image Author Topic: Attenuator question.  (Read 4103 times)
Offline Johntb
« on: August 19, 2016, 05:27:09 am »
I made the Plexi 18 watt. I would like to make an attenuator for it. I was planning on using this http://www.parts-express.com/speaker-l-pad-attenuator-15w-stereo-1-shaft-8-ohm--260-251 but noticed the 15 watt rating. Can I use this http://www.parts-express.com/parts-express-speaker-l-pad-attenuator-100w-stereo-1-shaft-8-ohm--260-264 instead and end up with a more useful one in the future?
Any other suggestions? I like the idea of stereo as there two outputs from the amp.
Thanks in advance for the help.
Proud to be self taught but, my teacher is an idiot.
Re: Attenuator question.
« Reply #1 on: August 19, 2016, 02:17:37 pm »
Buy the 12 buck one. But it might smoke. If you smoke it, buy the 24 buck one.
Kinda depends on if you can spend a little now and a little later, or prefer to spend for a too-good part in one go.
At this level, though I am not rich, I'd probably throw the $24. But I do remember living paycheck to paycheck to rent and not having 20 bucks all at one time.
Offline Johntb
« Reply #2 on: August 19, 2016, 04:44:48 pm »
Thanks.
After reading the 15 watt rating I kind of decided on the other one.
Thanks again.
