September 17, 2026, 11:19:35 am
Hoffman Amps Forum image Author Topic: Trainwreck-y Cathode-Biased and with a 5879  (Read 8754 times)
Offline Ledzepp007
« on: August 28, 2016, 08:52:47 pm »
Can it be done convincingly?
I hacked together some stuff and made an "idea" schematic.
Offline printer2
Re: Trainwreck-y Cathode-Biased and with a 5879
« Reply #1 on: August 28, 2016, 09:39:44 pm »
How much gain do you want?
Offline Ledzepp007
« Reply #2 on: August 28, 2016, 10:41:54 pm »
Is this a rhetorical question lol? Actually I would be aiming for about the same amount of gain as the normal TW circuit. Haven't adjusted the 5879 for that just yet. But looking for something along the lines of mu of 100 for the 5879, not EF86 levels.
My half-cocked idea is to put the 5879 in place of an AX7 not for more gain, but for different tone.
« Reply #3 on: August 29, 2016, 05:03:12 am »
I think that would work.  My guess is that when you get it built that you might need to lower the initial cathode cap values of 25uf to something more like 5uf.
« Reply #4 on: August 29, 2016, 05:13:29 am »
This is a Trainwreckish idea that I drew up a few yrs ago.  Never have built it.  I think a version could be done with 6V6's also.
« Reply #5 on: August 29, 2016, 07:13:15 am »
The Trainwreck style OT from Magnetic Components is 6.6kΩ.  You have a B+ of ~400vdc.  Why were you considering cathode bias?  What was your goal for choosing that over fixed bias, which would be more typical for 6V6's at that supply voltage?
Offline Ledzepp007
« Reply #6 on: August 29, 2016, 10:04:53 am »
I prefer cathode biased amps in general. There shouldn't be a reduction in amp stability, just efficiency, correct?
Offline MakerDP
« Reply #7 on: August 29, 2016, 12:13:47 pm »
Nothing wrong with cathode biased power if that's what you prefer. But something to consider... if you use a "large" cathode bypass cap then the sound of the power amp will become more like fixed-bias.
Offline Ledzepp007
« Reply #8 on: August 29, 2016, 02:59:57 pm »
Maybe 100uf to keep things from getting too flabby? 220uf?
Offline MakerDP
« Reply #9 on: August 29, 2016, 04:29:23 pm »
As Merlin told me on another site:
No bypass cap = Stiff, maximum headroom.
Smallish bypass cap = Squishy, minimim headroom.
Large bypass cap = Stiff (probably), minimum headroom.
He goes into it a little bit on his website in the PP Poweramp article.
By "large" we are talking 2200uF range. By "small" we are talking 25 to 100uF.
Some people put like a 50uF and a 2200uF on a switch so they can go back and forth at-will.
« Reply #10 on: August 29, 2016, 05:29:21 pm »
It's fine to use, and shouldn't impact efficiency much.
At 400vdc and a 6.6kΩ OT, you'll likely need a cathode resistor a good bit over 250Ω for optimum bias.  Tubenit can tell you the values he typically uses (usually between 300-400Ω?).
Folks here know better, but at a different site there was a lot of discussion to explain why cathode bias does not equal "more compression".  I was just making sure you weren't thinking along the same lines, while still using a supply voltage and OT that's otherwise suitable for 6L6.
« Reply #11 on: August 30, 2016, 07:21:57 am »
I mostly use 330ohm or 360ohm with cathode biased 6L6/5881 amps.   I have used 270ohm to 430ohm range with 6V6's.
