September 15, 2026, 12:18:11 am
Hoffman Amps Forum image Author Topic: 5f1 with dioderectifier?  (Read 5417 times)
Offline Oddvar
« on: September 04, 2016, 08:00:56 am »
Hi.  Is it oke to use four 1n4007 in a circle substituting for the tube?
Re: 5f1 with dioderectifier?
« Reply #1 on: September 04, 2016, 08:17:12 am »
No. But you can use two diodes connected as a conventional full wave rectifier. Sometimes there will be two diodes in series connected to each leg of the PT just to increase PIV. In that case there will be a total of four diodes, but they will not be connected in a circle.
Offline Oddvar
« Reply #2 on: September 05, 2016, 06:15:45 am »
Like this?
« Reply #3 on: September 05, 2016, 07:28:28 am »
NO
................ they will not be connected in a circle.
that is a Bridge Rectifier
Full Wave Rectifier need only two diodes, despite that you can see Full Wave Rectifiers that uses four or six diodes, but that is only to increase PIV
(the PIV of each diode in series adds to the preceding diode)
Here a Full Wave Rectifier, 2 diodes or 4 diodes or 6 diodes (and may be also more, but arranged this way)
« Last Edit: September 05, 2016, 07:30:59 am by kagliostro »
Offline drew
« Reply #4 on: September 05, 2016, 01:00:59 pm »
See http://el34world.com/charts/CommonHookups.htm (scroll down to "Power transformer hookup and rectifier info")
