September 14, 2026, 02:03:16 am
Hoffman Amps Forum image Author Topic: There is a A - B - A+B toggle switch ??  (Read 5112 times)
« on: September 08, 2016, 03:04:26 pm »
Exist a toggle switch that can do A - B - A+B connections ?
or the only way is a rotary switch ?
« Last Edit: September 08, 2016, 03:06:52 pm by kagliostro »
Re: There is a A - B - A+B toggle switch ??
« Reply #1 on: September 08, 2016, 03:16:01 pm »
Do you mean select A, or select B, or select A+B three position toggle? If so, yes, the C&K 7211 does exactly that. You can find them on eBay or through the big suppliers such as DigiKey or Mouser. Look at page 2 of this pdf to see how I'm using the 7211...
     http://sluckeyamps.com/VAC15/Vox_AC15_mods.pdf
« Reply #2 on: September 08, 2016, 03:29:03 pm »
Exactly that Steve, Thanks
Offline Tone Junkie
« Reply #3 on: September 09, 2016, 06:44:50 pm »
Thanks for finding this it will greatly help my plexi style builds.
Bill
« Reply #4 on: September 10, 2016, 11:27:36 am »
And it can do more
arranged in one other way I discovered it can be used for 3 inputs 1 output (or 1 input 3 outputs)
« Last Edit: September 10, 2016, 11:30:57 am by kagliostro »
« Reply #5 on: September 10, 2016, 12:54:07 pm »
Neat idea K! I think I'll steal that one. Thanks...  :icon_biggrin:
« Reply #6 on: September 10, 2016, 02:02:10 pm »
Neat idea K!
Oh, yes, I think so, but the idea isn't mine
I apologize if the way I've wrote the preceding post suggested that was an idea from me
although also I like it a lot
« Reply #7 on: September 13, 2016, 07:49:03 am »
On this side of the pond (and specifilally here) is not to easy to find a C&K 7211
however in Germany I can find some ON-ON-ON switch that are similar to the 7211 (also in dimensions)
Doing the search I've find an interesting ON-ON-ON product that is rated 10A 400V AC
I think this can be usable also for B+ switch if someone want to implement some "special" features on the amp
http://www.tube-town.net/ttstore/Switch/Toggle-Switch/Toggle-Switch-APEM-644-H-2-DP3T-ON-ON-ON::7379.html
