September 15, 2026, 03:13:47 am
Hoffman Amps Forum image Author Topic: this years project  (Read 5628 times)
Offline Shack
this years project
« on: October 04, 2016, 05:47:45 pm »
I could easily build a champ, vibrochamp....or single ended plexi, or....I could do a remodel of my blues jr, like I was intending.
I see lots of plexi pedals that run upwards of 250.00 to buy, if I built a plexi preamp what would be the best way to run it into like, say a HRD....in front or through the power amp in.....the line out on my tweed deluxe didnt work on the power amp in jack, probably a phase issue....and havent pursued it further.
I would like to make a single ended plexi, with a preamp out jack, to use as a preamp for the HRD somehow and see how it works
Is that worth the effort?   wish I could just try all projects
New build problems? Click here.
Re: this years project
« Reply #1 on: October 04, 2016, 06:12:22 pm »
If I understand, you wish to build a low power SE Plexi amp, with the option to run its preamp into a more powerful amp, like the HRD.  Sounds like a good idea.  In the Schematics Section Tubenit has schematics for preamp line out.  If you make the preamp line out adjustable with a pot, you should be able to feed it, at your option, into the bigger amp's input jack or line in.  (Be prepared to address possible hum issues.)
Offline Shack
« Reply #2 on: October 04, 2016, 09:04:08 pm »
perfect, thats exactly what im thinking  :icon_biggrin:
Offline Paul1453
« Reply #3 on: October 05, 2016, 05:18:33 pm »
I have not used any send and return FX jacks on my builds yet, but I have done this.
I have a 6V6 Plexi build that I made my own component board for.
It was basically a board with just the pre-amp components on it.
So I was working on designing an EL86 PP output section.
When I thought I had that worked out,
I snipped the wires to the tubes on my 6V6 Plexi's pre-amp board.
I then removed the whole circuit segment, pots included, in one big piece.
I wired up 3 12AX7 sockets in my new design,
and connected the Plexi's pre-amp circuit board with longer wires just laying outside the amp on my wooden bench.
It worked perfectly on the 1st try.   :icon_biggrin:
I don't see any reason why what you are proposing wouldn't work.
Only issue I think you might encounter is hum/noise from connecting two separate power supply circuits.   :icon_biggrin:
Offline Tone Junkie
« Reply #4 on: October 05, 2016, 06:43:28 pm »
use 1/4 inch jacks.
 On the pre amp put a ground lift switch so it runs on the ground of the power amp. if there's still hum use Merlins ground lift also. on pre amp grounding with a cap and resister.
Bill
Offline Shack
« Reply #5 on: October 06, 2016, 10:02:33 pm »
thanx for the replies...im thinking I may just start with the preamp and if all works well for me I will add the power section.....will build power supply for the whole thing and experiment as I go....the preamp is what I want the most, I dont use the practice amps I got now lol
but I love the low power Hi gain amps ive seen on you tube ....so one never knows
