September 14, 2026, 06:09:21 pm
Hoffman Amps Forum image Author Topic: Ampeg VT-22 on the bench for repairs...hum  (Read 6706 times)
Offline TubeGeek
    • Glacier Amps
« on: October 08, 2016, 10:33:24 pm »
Hey guys,  I have an ampeg vt-22 on the bench for repair.  I have seen this amp a few times over the past 3 years or so.  This time it's in for excessive humming. I made a short video clip of what I am dealing with.
https://youtu.be/BpbGiAaAzlg
I am going to trace out and study the power supply section first as I think the hum is coming from there.
I may need some help with this beast.
http://el34world.com/charts/Schematics/files/ampeg/AmpegVT22_V4_RevA.pdf
« Last Edit: October 08, 2016, 10:47:06 pm by TubeGeek »
Re: Ampeg VT-22 on the bench for repairs...hum
« Reply #1 on: October 09, 2016, 08:29:16 am »
My V4 has developed a similar hum.  An input jack is loose which may pose aground in issue.  Otherwise I suspect filter caps which are original from the early Seventies.  (That said, always suspect tubes first!) Even though you replaced caps in 2014 there could be a bad cap or ground in the PS.  Anyway I agree with your planned approach.
Offline TubeGeek
    • Glacier Amps
« Reply #2 on: October 10, 2016, 03:45:46 pm »
Well the problem wasn't much of a big deal.  v1 - 12ax7 had the hum.  With a new tube installed and the hum balance pot adjusted, the hum is acceptable now.
« Reply #3 on: October 10, 2016, 07:23:59 pm »
> hum is acceptable
These amps will never be "no hum" amps because the heater lines run on the PCB.
It was amazing how the "big hum" heard when you put your ear in "my" VT-40 really vanished a few feet away from the open-back cabinet. Don't think I'd want to hear it jacked into a large closed-back cabinet.
« Reply #4 on: October 10, 2016, 08:26:07 pm »
 :thumbsup:
