September 14, 2026, 03:25:15 pm
Hoffman Amps Forum image Author Topic: Fender Bassman clone start up issue..SOLVED  (Read 5885 times)
Offline Planobilly
« on: October 10, 2016, 06:42:16 pm »
Hi,
I have a new Bassman clone someone built that has a loud low frequency hum. The circuit is pretty close to a 6G6 schematic. The voltages are all within reason. The hum is present with all the preamp tubes removed. OP transformer is wired correct. I assume this is some wiring issue but not sure just where to look first. The guy who built the amp did a good job and I don't see any obvious problems.
Before I spend the time to go through the whole amp, any ideas of where to look first?
Billy
« Last Edit: October 11, 2016, 07:51:15 am by Planobilly »
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Re: Fender Bassman clone start up issue
« Reply #1 on: October 10, 2016, 07:07:18 pm »
sounds like filament, or 60hz coupling.  Any means to measure frequency with a meter or scope?
Offline Planobilly
« Reply #2 on: October 10, 2016, 07:30:56 pm »
Hi Shooter,
Just by ear it sounds like 60 hz. And yes I have a good scope.
I guess I will bite the bullet and go dig into the issue.
Billy
« Reply #3 on: October 10, 2016, 08:51:42 pm »
99% of all tube amps need to have a grounded heater CT or an artificial CT (the 2 qty 100 ohm resistors) or they will hum like a piece of construction equipment. It's an easy thing to leave out.....the first time. Then it's pretty tough to forget (on a build, which this is)
By the way....did this amp EVER work (without the gross hum) or did it develop the hum? Just asking you to prod your thinking.
I once worked in a factory that made pretty simple record players and CRT displays and I was the tech who fixed stuff that came fresh off the assembly line that simply failed the very first go/no-go test. It was important to realize that this gear NEVER worked right. It didn't "break". It NEVER worked properly. Many times I could fix 50 things in day if the gal who stuffed D22 in got every single one of them backwards that day. (The union guys hated me for that)
Offline Planobilly
« Reply #4 on: October 10, 2016, 10:25:04 pm »
Hi Guys,
The hum is 120.1 hz. The power transformer is not marked...I don't know who the mfg is. It has a center tap on the heater winding and I tested the grounding which is good.
Upon further inspection this looks like a 5F6A design and even perhaps one of Hoffman's. The turret board is blue and there are two turrets that would have  100 ohm to ground resistors for a PT with no center tap on the heaters. The control grid resistors are 1K and not 470 ohm like Doug shows on his drawing. I assume there may be several people who make these turret boards but I am not sure.
I don't currently know if the amp ever worked correctly. The cathodes are connected directly to chassis ground...no 1 ohm resistors and there is are turrets on the board to hook it up that way. Other than that, so far, it looks just like a Hoffman design.
It is getting late...i'll get back into this tomorrow.
Billy
« Reply #5 on: October 10, 2016, 10:40:59 pm »
If you have actually measured the hum freq and got 120 Hz it can't be anything except the power supply. First or second e-cap. End of story. Especially * 10 if there is still hum with the preamp tubes gone!
It *IS* possible for e-caps to be brand new or near-new and bad. It *IS* possible for them to be marked (and thus installed) backwards. Both really rare, but not impossible and not "never".
Offline Planobilly
Re: Fender Bassman clone start up issue..SOLVED
« Reply #6 on: October 11, 2016, 07:54:27 am »
The ground wire for the filter caps was just hooked on to another wire and not soldered.
Thanks for all the help.
Cheers,
Billy
« Reply #7 on: October 11, 2016, 08:57:39 am »
Hey man,  THANKS for posting the resolution!   I appreciate your taking the time to do so.
Offline bnwitt
  • Crankin' out the tone.
« Reply #8 on: October 11, 2016, 03:08:48 pm »
Billy
Yep, that what do it.
Offline Planobilly
« Reply #9 on: October 11, 2016, 03:18:22 pm »
Hi Tubenit,
Your welcome!
Sometimes the simplest issues can be difficult  to resolve. This is especially true for me when I don't know things like, who built this amp? Who provided the components? What schematic was used? Has it ever worked? Was there a gipsy woman involved?...lol
Well...lol...that's why we get paid the big bucks...lol
Cheers,
Billy
