August 29, 2026, 03:04:17 pm
Hoffman Amps Forum image Author Topic: Pedals in front of the Revibe  (Read 3998 times)
Offline Skip Hagey
« on: October 17, 2016, 02:52:14 pm »
What might be the pros and cons of using pedals in front of the revibe?  Could it overload the signal enough to adversely affect the revibes effect on the front end of the amp it is plugged into, ie making the reverb, lets say, get to intense or unmanageable? It just occurred to me that an overdriven signal might not respond well at the front end of the revibe...I understand that i should just try it and see what I get, but I was thinking a little more about theory, and I might not have or present all the combinations available. Thanks, Skip
Re: Pedals in front of the Revibe
« Reply #1 on: October 17, 2016, 03:13:55 pm »
Pedals will likely overdrive the revibe unit causing an unpleasant output sound. I just spent a lot of time dealing with a distorted revibe output due to a guitar with active pickups.
Offline MakerDP
« Reply #2 on: October 17, 2016, 09:58:35 pm »
Does the revibe work well in a serial effects loop?
« Reply #3 on: October 17, 2016, 10:17:04 pm »
The revibe is designed to work with instrument level signals.
