August 29, 2026, 03:03:29 pm
Hoffman Amps Forum image Author Topic: Champ blows fuse?  (Read 4988 times)
Offline Oddvar
Champ blows fuse?
« on: October 18, 2016, 04:33:37 am »
Hi.  I have just buildt a 5e1 amp.  But it blows the fuse as soon as I turn it on, even without the tubes in.  I have the Hammond 291AEX transformer.  It says 240 v is the two black leads.  Trouble is that one of the black leads has a white stripe, so I wonder if there might be some other leads, it has also has two white leads with red stripes and two brown onews, with a yellow stripe on one.  I have askes Hammond, but they don't answer.  Any suggestions?
Re: Champ blows fuse?
« Reply #1 on: October 18, 2016, 05:04:22 am »
Does the box have a sticker on it that id's each wire???
Do each of the same (main colour)colour wires have continuity????
Offline Oddvar
« Reply #2 on: October 18, 2016, 05:14:12 am »
No, they haven't.  I don't know what you mean by continuity?
Offline VMS
« Reply #3 on: October 18, 2016, 05:47:07 am »
Offline Oddvar
« Reply #4 on: October 18, 2016, 05:52:15 am »
Thanks, that must be it.  Why operate with two different schematics?
Offline Oddvar
« Reply #5 on: October 18, 2016, 06:00:13 am »
Black-Black/White is 120 v
Brown- Brown/white is 120 v.  To get 240 v should I connect Black/White and Brown/White then?
Offline VMS
« Reply #6 on: October 18, 2016, 06:13:17 am »
If you scroll down this page you see how to connect for 240V:
http://www.hammondmfg.com/300series.htm
In your case I believe you connect BLK/WHT and BRN together and BRN/YEL and BLK are your previous black wires.
Offline Oddvar
« Reply #7 on: October 18, 2016, 06:40:13 am »
Thanks again.  It worked...
