September 14, 2026, 11:17:16 pm
Hoffman Amps Forum image Author Topic: 15 an 8 ohm speaker in same cab?  (Read 4872 times)
Offline Oddvar
« on: October 28, 2016, 11:47:38 am »
Hi.  Is it possible to have a 15 ohm and a 8 ohm 25w speaker in the same cab in a Bassman 59?  I hav an old Greenback Pre Rola, 15 ohm, that I wanted to test?
Re: 15 an 8 ohm speaker in same cab?
« Reply #1 on: October 28, 2016, 12:08:49 pm »
Sure. Just connect to your 5.2Ω or 23Ω OT tap for maximum output power.  :wink:
Offline Oddvar
« Reply #2 on: October 28, 2016, 12:18:50 pm »
 :l2: ok, I'll rewind the transformer right away.  But seriously, would it be ok?
« Reply #3 on: October 28, 2016, 12:48:28 pm »
For test, sure. 4 Ohms is close for 16||8.
However the 8 Ohm job will take more power and be louder than the 16. Not sure what you are trying to test.
For the original purpose of a 2-speaker cabinet, THROWing across a large club, you want the two speakers identical and working in unison. Even if same brand/model, a 16 and an 8 won't take the same power and give equal output.
Many people do use mixed pairs for a different sound.
Offline Oddvar
« Reply #4 on: October 28, 2016, 01:25:18 pm »
I just want to test it. I have to Scumbacks in the cab now, they sound a bit thin.  And since I have this old Greenback on the shelf, thought I try, just checking, not for permanent use.
Offline 12AX7
« Reply #5 on: October 28, 2016, 07:44:30 pm »
This^^^
I tried it once and the lower one was louder to the point the other one wasn't really heard. Sounded like the one speaker alone.
