June 15, 2026, 12:45:41 am
Hoffman Amps Forum image Author Topic: 1 knob TS  (Read 6095 times)
1 knob TS
« on: October 30, 2016, 07:40:21 pm »
Looked for 1 knob TS, found this;
http://el34world.com/Forum/index.php?topic=9162.msg82661#msg82661
looked at (well drawn) schematic in reply 4;
Am I correct in assuming there is NO “junction” inside the circled area?
Re: 1 knob TS
« Reply #1 on: October 30, 2016, 07:48:54 pm »
Ordinarily, I'd think not. However, if there's no junction then what is that .01 connected to? IOW, what is it's purpose?
Re: 1 knob TS
« Reply #2 on: October 30, 2016, 08:13:54 pm »
I believe there is a junction.
Re: 1 knob TS
« Reply #3 on: October 30, 2016, 08:36:59 pm »
so CX becomes a cathode bypass?  does the .01 then become like NF for a freq range?
Offline VMS
Re: 1 knob TS
« Reply #4 on: October 30, 2016, 08:45:46 pm »
I think this works so that when you turn the tone the .01 cap becomes bypass cap.
So this tone would be much more effective without the Cx cap.
Offline VMS
Re: 1 knob TS
« Reply #5 on: October 30, 2016, 09:20:14 pm »
Some magnatone amps use this same tone control.
http://el34world.com/charts/Schematics/files/magnatone/magnatone_410rd.pdf
In this schematic you can see that when the tone is at zero the .001 cap is connected to ground and it dumps the high frequencies and when the tone is full you get a treble boost with the smaller than usual cathode bypass cap.
Re: 1 knob TS
« Reply #6 on: October 30, 2016, 10:30:03 pm »
Well-drawn, serious hacker, but I suspect a transposition error.
> the .01 cap becomes bypass cap. So this tone would be much more effective without the Cx cap.
And just 0.01 on a cathode would do little.
Dot the circle. Put the 0.68 where the 0.01 is. Put the 0.01 back in the drawers. See if that gives clear 2-way action. But I suspect much of the action is in the last wee bit of a turn.
Re: 1 knob TS
« Reply #7 on: October 31, 2016, 08:35:26 am »
That's what I want to avoid, I'm still pencil-whippin my build, just hunting for a 1 knob solution, if possible.  Thanks for the insight.
dave
Re: 1 knob TS
« Reply #9 on: October 31, 2016, 01:47:58 pm »
Out of all of them, I still like the Tweed Princeton tone control the best. Mind you the Big-Muff tilt control can be made to be fairly dynamic, (although it is somewhat lossier than the TP)
Re: 1 knob TS
« Reply #10 on: October 31, 2016, 02:07:05 pm »
Those are both on the short list.  but the tilt control I've seen adds a 2nd knob which I already have n want to eliminate.
Thanks Franco, the graphs are about what I'm getting with the BigMuff.
Most 1 knob'ers are integrated with a volume pot, can I assume it's NOT integral to the TS?
Re: 1 knob TS
« Reply #11 on: October 31, 2016, 02:18:02 pm »
Depends on how they relate to each other.
If the vol and tone controls are separated by another gain stage, then less so - although either vol or tone controls each can shape the frequency shelving to some extent on their own (remembering that the resistance between the vol pot's input and its wiper interacts with the miller capacitance of the following stage when the pot is dialled down, but this can be overcome with a 'bright' bypass cap).
But if the vol and tone controls are part of the same AC load on the previous stage, then interaction can't be helped.
Re: 1 knob TS
« Reply #12 on: October 31, 2016, 02:51:59 pm »
Thanks, that helps, I'm using mostly fixed R voltage dividers, (gain control), 'tween stages.
