September 15, 2026, 12:18:11 am
Hoffman Amps Forum image Author Topic: few questions on elevated heaters  (Read 6787 times)
Offline 12AX7
« on: November 04, 2016, 10:50:11 am »
I am thinking of doing this from the merlin site... http://www.valvewizard.co.uk/heater9.jpg
(the upper one, i have a CT)
It's basically a 2204 type build buy 6V6 and 18 watt transformers. Typical marshall JCM series fixed bias SS rectified, 3 gain stages then cathode follower. Is there anything i should know before trying this? Just wanna be safe. I was thinking of taking B+ from the PI node (around 300v i think) and a 220k/33k to 56k for the voltage divider and a 100uf cap and tweak the lower resitor till i get around 40v.  Am i missing anything ?
Also, is there a way to do this for V1 only? thanks.
Re: few questions on elevated heaters
« Reply #1 on: November 04, 2016, 10:59:57 am »
Sounds good to me.
Sure, but why??? You'll need a separate 6.3VAC filament source. The only tube that might benefit from this is the cathode follower that drives the TS.
Offline 12AX7
« Reply #2 on: November 04, 2016, 11:32:34 am »
Had a question in this post but i'm overwriting it after finding out for myself by doing the mod. Works fantastic. I used a 27k on the bottom to get just over 30v and it's dead quiet. I use tung sol reissues in V1 and i have 5 of them. But they hum like mad and this removed that 100% so i now have 5 good TS's instead of one barely usable one and 4 that are hideously noisy. Thanks for the help slucky ! :thumbsup:
« Last Edit: November 04, 2016, 12:00:33 pm by 12AX7 »
Offline trobbins
    • Tim's projects and info
« Reply #3 on: November 04, 2016, 08:55:30 pm »
Are you saying you tube-rolled five tubes in to V1, and they all exhibited a noticible hum on the output?  And then when you elevated all heaters in the amp, and tube-rolled V1 with those same valves, that there was no noticeable hum?
Offline 12AX7
« Reply #4 on: November 04, 2016, 09:13:54 pm »
5 tung sol reissues, yes. No other brands/models hum at all, just the tung sols. And yes, the tung sols are now as quiet as any other tube.
Offline trobbins
« Reply #5 on: November 04, 2016, 11:49:53 pm »
Hmmmm, that's interesting - they must do something consistently different than vintage manufacturers did with their heater elements.
Offline 12AX7
« Reply #6 on: November 05, 2016, 12:09:31 am »
It's a well documented issue with the TS reissues. It's only a problem tho with cascaded stages. You can use them in a low gain preamp or PI etc and they're fine But in V1 of a high gain amp they hum horribly. I didn't know if elevating the heaters would work but happily it did, and extremely well. I can't find another current production tube that feels and sounds as good to me in this amp at least as the TS reissue,  so i was on a mission to make them usable. Thankfully it was a successful one.
Offline Joel
« Reply #7 on: November 05, 2016, 04:01:19 am »
I've added heater elevation to all my amps.  It's especially useful in my JTM45 clone.  The Cathode Follower had a very high heater to cathode voltage which was causing intermittent noise.  Elevating 60V cured that.
The mouth of a happy man is filled with beer  - Egyptian Proverb
Offline 12AX7
« Reply #8 on: November 07, 2016, 12:02:52 am »
Another question....now that i have elevated the heaters by 30v is it ok to now run spiral filament tubes like the tung sol 12ax7 in the cathode follower position?
