September 08, 2026, 07:44:56 pm
Hoffman Amps Forum image Author Topic: Scratch Build Carlsbro ----- TC60  (Read 14993 times)
Offline HighFlyingV
« on: November 06, 2016, 02:04:39 pm »
[I have been searching for a home for this idea.
I posted on 18watt because I thought it would be a good idea to scale it down.
That being said it It is EL34 based and the more I think about it seems like a clone would be a better solution may need a VVR.
This one is a 2 channel , I would need to redraw the schematic to reflect single channel. I had been given the idea to build a EL84 1974x (scaled down ) and tweak it to the tone of the TC60 ?
http://m.imgur.com/gallery/UDhYGnV
« Last Edit: November 09, 2016, 10:45:44 am by HighFlyingV »
Re: Scratch Build Carlsbro Top 50
« Reply #1 on: November 06, 2016, 02:36:26 pm »
We like ideas. Come on in and drag up a chair. Take your shoes off and sit a spell.
Offline HighFlyingV
« Reply #2 on: November 07, 2016, 06:36:00 am »
Cool
Offline HighFlyingV
Re: Scratch Build Carlsbro ----- TC60
« Reply #3 on: November 07, 2016, 10:46:25 pm »
What are anyone's thoughts on building this as a 1974 TMB single channel , get it up and running and then tweak it to please ?
Offline silverfox
« Reply #4 on: November 08, 2016, 12:23:26 am »
Incredible amp. A couple of references for those interested.
http://emaushenric.benesser.se/?cat=37
A Demo: ! No longer available
I like the simplicity of this amp. I don't know what sort of mods are done yet. I'll be trying to find out from the posted data.
edit: upon closer inspection, the circuit values have been "Dumblized"
silverfox.
« Last Edit: November 08, 2016, 12:33:01 am by silverfox »
« Reply #5 on: November 08, 2016, 01:46:10 am »
Ciao HighFlyingV
Yesterday I've read your post and was convinced you are interested on the Carlsbro cs40 / 50 top
but I had nothing about to share, if instead you are interested on the CS60 TC, here you can find some documentation about a rebuild
(there is also a layout)
on this thread scroll down a bit to find the CS60 TC (post by bill bokey)
http://www.guitariste.com/forums/amplification,castle-made-of-sound-reparation-modification-d-amplis,483575,20.html
« Last Edit: November 08, 2016, 01:55:22 am by kagliostro »
Offline HighFlyingV
« Reply #6 on: November 08, 2016, 06:19:06 am »
Ciao HighFlyingV
Yes you are right , I'm sorry about that. I was going to leave the original and decided it would complicate things. Someone told me the top 100 was a slave amp ?
Did you draw that whole thing out , if you did I am real sorry.
« Last Edit: November 08, 2016, 06:39:38 am by HighFlyingV »
Offline HighFlyingV
« Reply #7 on: November 08, 2016, 06:25:47 am »
This guy has a blog with actual gut shots of one he modded. It sounds good modded:
« Last Edit: November 08, 2016, 06:38:46 am by HighFlyingV »
« Reply #8 on: November 08, 2016, 07:38:20 am »
Those transformers are not suited to an EL84 amp. Are you thinking about modding this existing amp or were you gonna just build a separate amp based on this schematic?
« Reply #9 on: November 08, 2016, 10:41:01 am »
Hell NO !  :icon_biggrin: :icon_biggrin:
I've find the documentation and only shared the link :grin:
Offline HighFlyingV
« Reply #10 on: November 08, 2016, 12:30:30 pm »
yes sir , build a seperate amp. I don't need a 50w amp but it does sound glorious to me.
I would try to keep it simple as possible to start out.
Probably build right from a Stout. Tmb and get it working first , right ?
Offline HighFlyingV
« Reply #11 on: November 08, 2016, 09:25:19 pm »
Unless I build it with the EL34's . I would need a layout  :w2:
Offline HighFlyingV
« Reply #12 on: November 09, 2016, 10:38:30 am »
sluckery If I did copy the TC60 (one channel) with EL34's what would I use for PT and OT?
Offline HighFlyingV
« Reply #13 on: November 09, 2016, 10:44:43 am »
Ciao HighFlyingV
Franco ,this the TC60 layout ? If I build this to that layout once figure out the Transformers and choke I can move forward.
« Reply #14 on: November 09, 2016, 11:33:03 am »
You must read the thread from which the layout comes from, those I posted previously
One thing, I don't think is useful to repurpose in each post what was previously posted, this way the thread becomes hard to be read
Ciao
« Reply #15 on: November 09, 2016, 11:38:20 am »
I would use the Marshall 50 watt PT and OT available from Hoffman. (Link at bottom of this page)
« Reply #16 on: November 09, 2016, 11:43:49 am »
Oh, the thread is in french, not english ......
OK, the amp was a Carlsbro PA100 missing of some components (as transformers) and was converted in a CS60 that the guy liked more than the PA100, he say that he copied the layout from an original CS60 he had under hands previously
Offline HighFlyingV
« Reply #17 on: November 09, 2016, 06:21:24 pm »
Thanks Franco , and good advice. I know little about the old  Carlsbro amps and their layouts because they are not so common in the states . The particular player of interest (Bill Nelson) played a Top 100.
I don't know the difference between the Top 100/50 and the TC60 . I have seen the term TC60Cs , I know TC is twin channel. I have seen that top 100 is 4 hole no big deal.
The TC has Bass Treble for each channel.
Yes , that site is in French . I could look at with Google translate.?
As of this point I am going to build the TC60 as it is drawn. I have to decide if I want 2 channels.
« Last Edit: November 10, 2016, 05:16:44 pm by HighFlyingV »
« Reply #18 on: November 10, 2016, 01:59:18 am »
The two channels are very close each other but not perfectly the same
in the upper channel the coupling cap is .01 and the mix resistor is 330K
in the lower channel the coupling cap is .047 and the mix resistor is 470K bypassed with a 500pf cap
you can build one channel, add a switch to change the coupling cap value and tailor the mix resistor + bypass cap at your taste
you must only cut out the existing layout as to have only one channel
p.s.: I took a look to the layout .... seems that there are differences if compared to the CS60-TC schematic, it recall the PA60 schematic, see the common cathode resistor and bypass cap
« Last Edit: November 10, 2016, 02:46:50 am by kagliostro »
Offline HighFlyingV
« Reply #19 on: November 10, 2016, 09:16:50 pm »
Franco , I have found a little info digging around. It seems that the layout of this is integral as is every part to the tone. For Example cutting the channel ,channel 1 is clean and 2 is more driven , one of them is   wired for a bright channel and the channels can be jumped. It has bass and treble on each channel and the top cut. I can't explain how it works because I just don't have the knowledge like lot's of you guys here.
The guy that you posted from France (Bill Bokey) has several youtube videos.
https://www.youtube.com/watch?v=8ragJ46w9r8
One other I found is redundant (same chords) but it does show different channel tones with a tele.It does help that it fairly clean :
https://www.youtube.com/watch?v=E8pgOff4R_I
« Reply #20 on: November 11, 2016, 09:14:04 am »
I wrote to Bill and he told me that the resistor and bypass capacitor ov V1 & V2 are shared, so the layout follows the schematic
give a look to this schematic as to understand better
and then look to the previous schematic
and note that V1 & V2 cathode resistors are labeled as R1 & R1- C1 (the other is missing) and R2 & R2 - C2 & C2
Bill has a personal site here (if you want you can contact him, he is a very kind person)
http://www.castlemadeofsound.com/
The preamp are very close each other, the difference is one feed the PI via a 330K mix resistor, the other via a 470K mix resistor bypassed by a 500pf cap, obviously the signal feeded via the 330K resistor appears to be strongher that that feeded via the 470K resistor
If you want you can use only two input jack and use a switch to feed one channel or the other or both at the same time, Sluckey used a C & K 7211 ON-ON-ON switch to perform this thing in a Vox AC15 he has build (very cool amp http://sluckeyamps.com/VAC15/ac15.htm - http://sluckeyamps.com/VAC15/Vox_AC15_mods.pdf)
« Last Edit: November 11, 2016, 09:29:55 am by kagliostro »
Offline HighFlyingV
« Reply #21 on: November 12, 2016, 06:36:26 am »
 :headbang:
Offline HighFlyingV
« Reply #22 on: November 13, 2016, 03:50:17 pm »
I would contact him but there is a language barrier.
I would do tagstrip. Follow his layout.
« Reply #23 on: November 13, 2016, 04:04:58 pm »
He reads also english (if you try to be simple)
Tagstrips, yes, doable, why not eyelet or turret ?
« Last Edit: November 13, 2016, 04:11:20 pm by kagliostro »
Offline HighFlyingV
« Reply #24 on: November 14, 2016, 08:11:08 pm »
I have never done an eyelet board but it doesn't look to hard.
« Reply #25 on: November 15, 2016, 01:14:06 am »
The more difficult thing is to draw the hole position with the right distances
then an eyelet board is easy to be build
Offline HighFlyingV
« Reply #26 on: November 19, 2016, 10:05:51 am »
It looks like it takes 700v secondary 350 - 0 - 350 to get 460v on the power B+. Hammond makes a 273x or 273bx ( higher ma) 201ma which sounds to high to me. Franco , like you said the choke and placement of the choke is very important is amp according to Bill. I spoke him on Facebook.
« Reply #27 on: November 19, 2016, 03:21:31 pm »
I don't know the spec of the original OT, however 201mA didn't seems too much for that amp, may be 300-350mA is a better choice (to me)
here is the application data of EL34 tubes, give it a look
I would like to read the opinion of someone that is more skilled than I'm
« Last Edit: November 19, 2016, 03:29:25 pm by kagliostro »
Offline HighFlyingV
« Reply #28 on: November 19, 2016, 10:32:48 pm »
Marshall JTM 50 power by classic tone has 150ma which has 5 tubes.
Offline HighFlyingV
« Reply #29 on: November 25, 2016, 08:48:06 pm »
I have a plan , I just happened on a blank chassis but it's only 16 × 8 x 2 . I will get a universal board.
Seriously looking at Edcor iron.
« Reply #30 on: November 27, 2016, 01:12:00 pm »
Wait for the opinion of other, but to me it is short, 16" seems short for a 5 tube amp, also if you have an 8" on the other measure
« Reply #31 on: November 27, 2016, 05:21:53 pm »
My Dual Lite and Plexi 6V6 both have 6 tubes. Chassis are 12.5" x 6.5" x 2.5".
Offline HighFlyingV
« Reply #32 on: August 30, 2017, 03:20:15 pm »
I might get back to this idea but as someone pointed out somewhere build a 18w lite llb and then change the pre amp to the Carlsbro pre amp. And be done.
From the Top 50 Carlsbro
http://imgur.com/a/akKOZ
« Last Edit: August 31, 2017, 07:38:27 am by HighFlyingV »
