August 29, 2026, 03:02:50 pm
Hoffman Amps Forum image Author Topic: Trouble with tubes in Hoffman AC30 build  (Read 7702 times)
Offline Oddvar
« on: November 19, 2016, 06:43:43 am »
Hi.  I just bought a set of nos Sylvania EL84 for my AC30 Hoffman build.  For some strange reason they only work in V4.  In all other positions the make a terrible, crackling nois.  My original tubes, reissue Mullard, JJ. RCA an GT tubes work just fine.  I wonder if there's a problem with the voltage in V5/6/7?
I had 4 Shuguang tubes, they all burnt out, in all positions.
Any suggestions?
Re: Trouble with tubes in Hoffman AC30 build
« Reply #1 on: November 19, 2016, 08:36:19 am »
might be, what ARE the volts at those plates?
« Reply #2 on: November 19, 2016, 08:42:06 am »
Is pin 1 connected to pin 2 inside those Sylvania EL84s? Use your ohm meter to verify.
« Reply #3 on: November 19, 2016, 12:15:15 pm »
Did your Shugang tubes "burn out" after a normal life (at minimum, many months) or did they burn out immediately or super fast after you installed them?
There are some amps that run EL84 really really hot so nobody expects decade-long life out of them, I'm just trying to get an idea if your Shugangs are reasonable quality tubes in a general sense.
Offline Oddvar
« Reply #4 on: November 19, 2016, 12:26:09 pm »
The shuguangs didn't make it through 15 min.  But other tubes works very well?
Offline Oddvar
« Reply #5 on: November 20, 2016, 09:10:10 am »
The plate voltage on the v4 and v5 is 326, v6 and v7 is 327/8. Should it be a bit lower?
« Reply #6 on: November 20, 2016, 11:05:41 am »
max Plate is 300ish so I'd say yup.  For high gain-ish I like around 180ish at plate, low gain-ish I like 100 to 120ish at plate.
EDIT: by the time I got to the schematic and typing, V 567 became V 123 :cussing: :BangHead:
« Last Edit: November 20, 2016, 07:24:15 pm by shooter »
« Reply #7 on: November 20, 2016, 11:40:49 am »
Offline Oddvar
« Reply #8 on: November 20, 2016, 12:10:34 pm »
When I measure pin 1 and 2, it's moving around a bit, but in the area of 0.4/8 ohm?
« Reply #9 on: November 20, 2016, 01:00:31 pm »
That means they are connected together inside the tube. Do the bad shuguangs have low resistance between pin 1 and 2 also?
Look at this RCA 6BQ5. You can see pin 1 and 2 tied together. I'll tell you why this may be important shortly...
Offline Oddvar
« Reply #10 on: November 20, 2016, 01:37:00 pm »
On the Shuguangs there are no reactions, some are visibly connected at two, some aren't.
The Sylvania tubes have no connection on two, just a loose pin sticking up.
Offline Oddvar
« Reply #11 on: November 21, 2016, 07:34:27 am »
Seems like the NOS EL84s have internal connections between pins 1 and 2 where modern EL84s do not. Since the resistor goes from pin 1 to pin 2, that might be a problem?  Any solutions?
« Reply #12 on: November 21, 2016, 07:45:39 am »
It's not an issue between NOS and modern tubes. It's just an inconsistency between tube manufacturers. You will find some NOS tubes that don't have pin 1 and 2 connected, others that do. Same with modern tubes also.
Just don't mount the resistors between pins 1 and 2. The easy thing to do is connect one end of the resistor to pin 2 and connect the wire from the board to the other end of the resistor. Do the same for all 4 resistors.
I don't know that this will cure your odd problem but it's worth a try. Sometimes odd problems need odd fixes. One thing for sure though, get that resistor off pin 1 and then you can use any EL84/6BQ5 without shorting out the grid stopper.
« Last Edit: November 21, 2016, 07:48:38 am by sluckey »
Offline Oddvar
« Reply #13 on: November 21, 2016, 07:54:59 am »
The board wire goes to pin 9, should I connect taht to the resistor so it uses pin 2? Or?
« Reply #14 on: November 21, 2016, 08:02:49 am »
No it doesn't. LEAVE PIN 9 ALONE! We're talking about the board wire that goes to pin 1.
Offline Oddvar
« Reply #15 on: November 21, 2016, 08:05:11 am »
ok, get it, got it, good, as Danny Kaye would say.
« Reply #16 on: November 21, 2016, 08:33:42 am »
I really don't like to have wires just connected to the unsupported end of a resistor. This is how I'd do it...
Offline Oddvar
« Reply #17 on: November 21, 2016, 08:45:38 am »
Thanks, great way.
