September 17, 2026, 05:14:53 am
Hoffman Amps Forum image Author Topic: AC30 again, too hot?  (Read 4272 times)
Offline Oddvar
« on: November 24, 2016, 05:55:41 am »
Hi again.. The Hoffman AC30 proved to be hard to get right, for me at least.  I unconnected  pin 1 on the four powertubes, thanks to Sluckey.  Now the nos Sylvania tubes worked for a while, then the volume just faded and died.  I put in some other tubes in and the worked.  I am beginning to wonder if the voltage is too high, seems like the burn iside is increasing on some tubes.  Is there any way to lower the bias?
Re: AC30 again, too hot?
« Reply #1 on: November 24, 2016, 07:16:45 am »
Increase the value of R34. I'd try 68, 75, 82, or 100. Must be rated for 10 watts. Higher values means tubes run cooler.
The AC-30 is well known to be a hot amp, especially with the original chassis/cab design.
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #2 on: November 28, 2016, 11:37:10 am »
yes Sluckey helped me with this same issue on mine, it was running a bit hot and I dialed it back down a bit by trying different resistors, i think mine ended up best at 125 Ohm, but I don't recall off the top of my head.  Yours likely will be a touch different because every circuit is a bit different due to the variance in resistors in the path etc, and performance of the overall circuit.  (Or so I understand).
~Phil
Phil Davis
tUber Nerd =|D
Offline Mark
« Reply #3 on: November 29, 2016, 03:09:16 am »
What voltage is on the anode/plate of the EL-84's?
What is on the screens?
I assume you are using a 50 ohm resistor and have about 13VDC across the resistor?
These amps run ridiculously hot, they certainly exceed the specifications of the valves.
Regards
Mark
