September 16, 2026, 10:02:00 pm
Hoffman Amps Forum image Author Topic: question RE: PT tap  (Read 5553 times)
Offline 12AX7
question RE: PT tap
« on: November 27, 2016, 12:33:35 pm »
I have a unused tap on my PT that has 3 wires, a common and 2 taps one for 6.3v and one for 5v. (no, the 6.3 isn't for heaters it has a dedicated heater winding) Is there a way to combine the 2 taps to get more V or a way to double one of them easily?
Re: question RE: PT tap
« Reply #1 on: November 27, 2016, 01:06:31 pm »
This separated 0-5v-6.3v winding seems devoted to the tube rectifier (a 5v or a 6.3v rectifier)
Which is your purpose ? What do you want to do with this supply ?
Offline drgonzonm
« Reply #2 on: November 27, 2016, 01:48:04 pm »
Send us the data from the transformer.  We might be able to get a schematic for the xfrmr.
Offline 12AX7
« Reply #3 on: November 27, 2016, 02:13:54 pm »
I have one, but i think i've found a way to do what i needed. If it doesn't work out i'll post back but it seems to work.
Offline 12AX7
« Reply #4 on: November 27, 2016, 04:18:25 pm »
This is what i wired up and it works tho i'm not sure how smart this is having about as much electronic theory as a chimp. So maybe someone can tell me if this is ok or will be problematic. Note the resistor with a ? next to it. I actually wired a 5k pot there and at 5k the LED still lights tho a bit dim. The relay coil is 100R as noted. The relay is rather 9vDC i think, but it seems to trigger strongly and reliably with 6.3v. If this is an ok way to go about it, what would you recommend for a resistor value? If not, how would you suggest i wire it?
« Last Edit: November 27, 2016, 04:36:53 pm by 12AX7 »
« Reply #5 on: November 27, 2016, 05:29:29 pm »
What you have is fine. I'd use a 1K resistor. 470Ω would be really bright with 9V.
« Last Edit: November 27, 2016, 05:32:37 pm by sluckey »
Offline 12AX7
« Reply #6 on: November 27, 2016, 05:34:31 pm »
It's not powered by 9v, it's 6.3. I was just saying the relay may be a 9v but it works fine at this voltage.
« Reply #7 on: November 27, 2016, 05:44:41 pm »
I know that. Now measure the dc voltage across that 470µF cap. Bet it's pretty close to 9VDC.
Offline 12AX7
« Reply #8 on: November 27, 2016, 05:46:53 pm »
Ahh, i see. Thanks slucky.
