August 15, 2026, 07:51:01 pm
Hoffman Amps Forum image Author Topic: Low Powered Tweed Twin Issues - Help...  (Read 7357 times)
Offline p2pAmps
    • p2pAmps
« on: December 01, 2016, 09:00:24 am »
Guys, I will try and make this brief.
I had a custom-shop Low Powered Tweed Twin come in the shop yesterday.  The complaint was barely any sound and some smells.  This is a dual rectifier (5U4) amp but showed with only one rectifier in place.
After replacing all the tubes with UBGs (used but good) to test, I brought it up slow and the 1st thing I noticed was it was pulling just south of 2A on my variac @ 90vAC.  As the rectifiers started coming up I heard some light popping and my amp meter was bouncing around, I immediately shut it down.  Next I killed all the lights in the shop and brought it back up slow to see if I could detect any arcing on the sockets.  That went ok, no arcs.
Next move, I pulled both 5U4s and turned it back on @ 90/100 vAC.  This time I did not get current draw.  I was getting around 350vDC on the filter cap.  I put the rectifiers back in and fired it again @ 90v, once the rectifiers started to warm the voltage on the filter cap started to fall instead of rise.  Hummm
I am very suspicious that MM power trannies is bad and that may very well be where the popping and smells were coming from.
Am I making any since whatsoever …
Now remember on any replies to speak simple English as I am not at the level as some you you experts LOL  :icon_biggrin:
Scaggs
Everything Affects Everything
Re: Low Powered Tweed Twin Issues - Help...
« Reply #1 on: December 01, 2016, 10:47:31 am »
Huh??? How could you possibly get any voltage on the first filter cap if both 5U4s were pulled? Totally discharge that cap and try that again.
Offline p2pAmps
    • p2pAmps
« Reply #2 on: December 01, 2016, 10:48:28 am »
Agreed Steve, the caps were discharged.  This is a very strange issue
« Reply #3 on: December 01, 2016, 10:59:02 am »
Humor me. Please try that again.
Offline p2pAmps
    • p2pAmps
« Reply #4 on: December 01, 2016, 11:02:05 am »
LOL, ok Steve...  I know it sounds crazy.  I checked it twice too.  Hopefully Mrs Scaggs will let me escape to the garage tonight.
« Reply #5 on: December 01, 2016, 02:55:11 pm »
You said it's custom shop. Maybe the builder put diodes || with the rect. tubes? Although I'm sure you'd have seen those.
« Reply #6 on: December 01, 2016, 03:16:12 pm »
John has an excellent thought. Are you inside the chassis and can you check for diodes? With no 5U4s in there it can not work (by "work" I mean, there ain't no rectifier in there so no DC so no amp).....w/o diodes.
Offline p2pAmps
    • p2pAmps
« Reply #7 on: December 05, 2016, 11:30:11 am »
Yes it was a bad MM power trannie...  Yes Steve, I did lose my mind temporarily on the FC voltage thing :)
« Reply #8 on: December 05, 2016, 01:28:17 pm »
PT's don't usually fail without some help...
I'd consider fusing the secondary for future protection.
http://www.valvewizard.co.uk/fuses.html
Keep up the good work Mike!
Offline p2pAmps
    • p2pAmps
« Reply #9 on: December 06, 2016, 10:01:20 am »
Yeah, this is one of those Fender Custom Shop amps and the secondaries are fused from the factory...  It's all fixed and gone now, next......
« Reply #10 on: December 06, 2016, 10:22:34 am »
know what killed the tranny?, did you wind up re-tube-ing ?
EDIT: Fixed moderator-modified message - HBP
« Last Edit: December 06, 2016, 11:48:13 am by HotBluePlates »
Offline p2pAmps
    • p2pAmps
« Reply #11 on: December 06, 2016, 11:27:28 am »
Never found the actual source of the (Mercury) tranny issue.  Tubes all checked out and after changing the PT all the voltages became normal and as expected.  I bench tested for 48 hours and it was stable.  Not a big Mercury fan
« Reply #12 on: December 06, 2016, 12:01:38 pm »
If the missing one shorted out, would that have done the dirty?
EDIT: Fixed moderator-modified message; you're killing me p2p! - HBP
« Last Edit: December 06, 2016, 02:03:39 pm by HotBluePlates »
Offline p2pAmps
    • p2pAmps
« Reply #13 on: December 06, 2016, 01:17:35 pm »
Possible I suppose.  I did add a second rectifier back to the amp so it would be stock.
