September 18, 2026, 07:25:23 am
Hoffman Amps Forum image Author Topic: A new fault/sound I had never seen before  (Read 4174 times)
Offline Planobilly
« on: December 12, 2016, 04:00:08 pm »
Hi Guys,
I just repaired a Fender Blues Deville 212. The drive channel made a sound like a small motorcycle and got louder as the master volume was turned up. I had never seen a amp act just like that. I assumed the issue was a cap somewhere and that was a correct assumption. I found a defective 22uf filter cap and problem solved.
Motorboating I have listen to but motorcycling was a new one on me...lol
Anyone have any idea how a bad cap actually causes the sort of noise/oscillation?
Cheers,
Billy
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Re: A new fault/sound I had never seen before
« Reply #1 on: December 12, 2016, 05:14:43 pm »
So you had motorboating which was a few-Hz higher in frequency than what you usually hear...  Mechanism will be exactly the same.
The ear tells you there is a big difference between setting your trem to minimum speed (maybe 4-6Hz) and maximum (maybe 10-12Hz), but that depends on your perspective (doesn't look like a lot when just talking numbers).
Offline Planobilly
« Reply #2 on: December 12, 2016, 06:12:46 pm »
Thanks for the feedback. No pun intended..lol
Just a strange sound I had just never experienced before.
Cheers,
Billy
