September 17, 2026, 11:34:18 pm
Hoffman Amps Forum image Author Topic: Single-Ended Plexi Build Help  (Read 6757 times)
Offline Big_Mike
« on: December 15, 2016, 08:56:22 am »
I ran across a very interesting schematic for a single-ended Plexi with a pseudo-phase inverter for a presence control and extra gain.  The schematic is attached.
I have a couple of questions, and will need some help on this:
1.  Would I be able to use the Hoffman stout chassis for this build?  Will there be enough room?
2.  I need some help converting the schematic into a PTP board layout.  If someone could help me with that, I would very much appreciate it.  Thanks so much.
Re: Single-Ended Plexi Build Help
« Reply #1 on: December 15, 2016, 09:31:19 am »
The Stout should work fine, tight but works, I've built 2 amps on the chassis using 2 pre, 2 power tubes.
download dougs plexi6V6 layout, then with your favorite editing software cut/paste the "new" values n components.  I just did a 2ch twin type layout based off somebody else's layout that was close.  take your time, re-work as much as needed on paper so you don't have to do it with solder!
Offline Big_Mike
« Reply #2 on: December 15, 2016, 10:38:18 am »
Just as an FYI, here is a link to the webpage where I found the schematic and a write-up on the amp.  There is also a clip there which sounds pretty good:
http://chasingtone.com/dvnator/the-seplex/
Offline BetterOffShred
  • I play tube amps..
« Reply #3 on: December 15, 2016, 11:39:49 am »
Cool site, thanks for the link!   His projects all look pretty interesting.
Offline Glenn
« Reply #4 on: December 15, 2016, 12:15:40 pm »
hi Big_Mike. the link you posted has a layout already there.
its just under the schematic...
with respect, Joe
Offline Big_Mike
« Reply #5 on: December 15, 2016, 12:48:30 pm »
with respect, Joe
Thanks, I totally missed the link to the drawing on his site.  I will try and convert his tag board into something more compact to use with the Stout chassis.
