September 17, 2026, 07:44:25 am
Hoffman Amps Forum image Author Topic: Mysterious crackling sound in new Champ build  (Read 5322 times)
Offline fingersoccer
« on: December 18, 2016, 12:00:34 pm »
I finished putting together a BF Champ-style amp and it sounds pretty great—except for a crackling sound that happens when playing with the volume above 3; the louder I play, the more likely the crackling sound is. Playing quietly produces no irregular artifacts.
I assumed this was due to a bad/missed solder joint, so I opened the amp and reflowed all the connections, double-checking my work with a bright light from a few angles to make sure I didn't miss anything. Still, when I tap on the side of the chassis (no guitar plugged in), I get the same crackling sound. I prodded every wire in the amp using a chopstick and the only place I'm getting any response is from the power transformer 320V secondaries. Additionally, if I tap ever-so-lightly on the chassis near the PT with the chopstick, the sound comes back. So I'm pretty sure that something in/near the PT is causing the crackling, but I'm fairly confident it's not the joint the secondaries make to the rectifier tube.
Here's a YouTube video showing how I'm able to reproduce the crackling sound: https://youtu.be/pWq2yjFahHE
I'm hoping this doesn't mean a bad PT—it's a brand new ClassicTone and I don't relish the idea of purchasing a new one. Any ideas on what this could be or further troubleshooting steps I could take to help narrow this down? Thanks!
« Last Edit: December 18, 2016, 12:03:52 pm by fingersoccer »
And evermore in the world is this marvelous balance of beauty and disgust, magnificence and rats.
Re: Mysterious crackling sound in new Champ build
« Reply #1 on: December 18, 2016, 12:27:42 pm »
Long shot... Disconnect the negative feedback wire from the speaker jack. Still staticky?
« Reply #2 on: December 18, 2016, 02:49:56 pm »
Another couple long shot ideas. Swap rect. tube. Tap on  the first couple resistors & filter caps.
« Reply #3 on: December 18, 2016, 02:53:12 pm »
Just watched your video. Forget the restistor/cap idea. That sounds nasty!
« Reply #4 on: December 18, 2016, 03:21:18 pm »
sluckey, I have a switch on the back panel that engages or turns off the negative feedback—nothing changes, crackle-wise, in either position. Are you thinking that physically disconnecting the wire would a difference here?
« Last Edit: December 18, 2016, 03:26:45 pm by fingersoccer »
Offline upnorth2
« Reply #5 on: December 18, 2016, 03:50:14 pm »
If you can, check your voltages (PT) while the "noise" is happening. Doesn't sound like the crackle of a cold solder joint to me.
« Reply #6 on: December 18, 2016, 06:38:37 pm »
Can you get your sniffer close without electrocution, do you smell ozone, mild odd electrical?  I can't smell my wife's cooking, but I can smell minor arcs from 100yrds  :icon_biggrin:
« Reply #7 on: December 19, 2016, 10:14:09 am »
upnorth2, I'll check the PT voltages today after work and report back. I'm guessing that if the voltage goes haywire while the crackling happens, that means something foul is afoot.
shooter, I haven't smelled anything out of the ordinary as yet, but I'll keep my nostrils open.
« Reply #8 on: December 19, 2016, 06:56:19 pm »
Alright, I checked the PT voltages using the Geofex power transformer page as a guide. The numbers all like they should, as far as I can tell. Voltages didn't change at all when probing 'round with a chopstick.
LeadExpectedActual
Primaries (BLK)120V121V
Filaments (GRN)6.3V7.13V
Rectifier (YEL)5V5.66V
HT Secondaries (RED)320V352V
There were no tubes in place when these voltages were taken—do you think installing them and taking more readings would give any additional insight?
I've also swapped out the 6V6 and 12AX7 tubes with ones known to be good to no effect.
« Last Edit: December 19, 2016, 07:05:37 pm by fingersoccer »
« Reply #9 on: December 19, 2016, 07:05:16 pm »
guessing the crackling still present without tubes and the volts stayed constant while it crackled ?
« Reply #10 on: December 19, 2016, 07:07:06 pm »
shooter, yep, the voltages stayed constant even when tapping with the chopstick. I didn't try hooking anything up to the speaker w/o the tubes though—I'll try that now.
« Reply #11 on: December 19, 2016, 07:10:53 pm »
No sound at all when I turn on the amp and tap without the tubes in. I guess that's expected though, right, since there's no amplified signal getting to the speakers?
« Reply #12 on: December 19, 2016, 07:18:55 pm »
ya, I was thinking you may have been able to hear "arcing" without the amplified sound, which in itself is probably a good thing you can't.
