September 08, 2026, 09:38:16 pm
Hoffman Amps Forum image Author Topic: Video of the buzz issue with the AB763 new build  (Read 4546 times)
Offline Planobilly
« on: December 26, 2016, 11:42:40 am »
I hope the audio is clear enough for you to hear the issue.
Any ideas?
Thanks,
Billy
Between fishing, flying, and fooling around with guitar amps, somehow 70 years got behind me. Shorter of breath and one day closer to death as the song goes.
Offline dunner84
Re: Video of the buzz issue with the AB763 new build
« Reply #1 on: December 26, 2016, 05:27:42 pm »
Wow, that is really odd. I hope someone has some insight for you. You almost need a signal generator and an o-scope.
Offline whoops
« Reply #2 on: December 26, 2016, 09:09:01 pm »
Hi,
can you post the voltages?
What AB763 circuit did you build? Hoffman, Fender, 1 channel , 2 channels, etc?
Offline silverfox
« Reply #3 on: December 27, 2016, 01:28:09 pm »
I'm going to advance the "notion" it's a capacitor. Check the filter capacitors since it is most prominent on low frequencies. Could also be a cathode capacitor. Again, just a suspicion.
silverfox.
Offline Planobilly
Re: Video of the buzz issue with the AB763 new build (FINALLY Solved)
« Reply #4 on: December 28, 2016, 10:07:46 pm »
Hi guys,
In the strange world of tube amps this problem turned out to be a simple bad tube socket. I could not find the issue by the normal process of rocking or twisting the tubes around.
I had to disconnect stuff and test stage by stage to narrow down the issue to V2.
I too thought this would turn out to be a failing capacitor.
So...as of this point in time, the amp works and sounds as it was designed.
I did have a couple of other component failures that caused me some grief. Perhaps bad components, perhaps I overheated them, perhaps all this is just normal for someone who lives in the Bermuda Triangle...lol
Cheers,
Billy
