September 13, 2026, 12:16:00 pm
Hoffman Amps Forum image Author Topic: Peavey MACE hiss problem  (Read 8083 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: December 28, 2016, 05:54:27 pm »
Hola amigos, long time no see !
A friend of mine brought me a Peavey MACE guitar amplifier ( 6 X 6L6's ), SS preamp.
The amp plays but there is a loud hiss comin'out of it. To me, it's not a heater, bad cap or grnd issue, because I never heard such a noise. I have swapped the 6L6's, same problem. Any tip ?
Colas LeGrippa
P.S.: call me Alvin.
Re: Peavey MACE hiss problem
« Reply #1 on: December 28, 2016, 08:32:02 pm »
SS preamp
Does the amp have a line out, or pre out?  if so, see if you hear it there.
« Reply #2 on: December 29, 2016, 05:00:56 am »
For those of you  who may not know Colas,  check out his video of impersonating Alvin Lee at Woodstock!  GREAT playing and performance!
I've heard Colas play some Johnny Winter also that was incredible.
https://www.youtube.com/watch?feature=player_embedded&v=rQb0OoCR1vI
« Reply #3 on: December 29, 2016, 01:50:01 pm »
I agree with this idea.  You could run the preamp into another amp's power section to see if hiss  is there.
OR .......... run another amps preamp into this amps' power section.
Maybe trying that will isolate where the hiss is coming from?  I don't know enough about solid state components to offer good advice to you.
« Reply #4 on: December 29, 2016, 08:17:35 pm »
Hiss is usually the small tubes, not the big tubes.
Noting what the knobs do to the hiss helps to narrow down which stage it is.
Offline whoops
« Reply #5 on: December 29, 2016, 10:20:59 pm »
The hiss is probably from the preamp section.
Or from the solid state Phase inverter circuit.
Like other members said, you should separate the section first. It's easy on this amp since you have on the back Preamp Output and Power Amp Input jacks
Connect the Premp Out  to another amplifier or power amp, is the hiss there?
Connect another known non hissy preamp to the power amp section, and check for the hiss also, is it there?
Then you will know which part of the circuit is the hissy one
The amplifier has a lot of different inputs do all of them hiss?
Record the noise and show us, could also be a video, then it's easier to know what type of hiss/noise you're having.
« Last Edit: January 02, 2017, 08:02:16 pm by whoops »
  • MAKE LOVE NOT WAR
« Reply #6 on: December 30, 2016, 08:46:26 am »
Cool, Tubenit, it's been a long time since I watched this video LOL, with the wig....
Thanks for your replies. I think the hiss comes from the preamp too, I'll try to isolate where it comes from and will get beack to you. I don't feel like replacing transistors one after another till the problem goes away....
Have a good day........AND A GOOD YEAR TOO ( no, not the tires...)
Colas LeGrippa
Offline whoops
« Reply #7 on: December 30, 2016, 09:01:06 am »
Colas LeGrippa
Well if it's the preamp use a signal probe, if you don't have one it's easy enough to do, there's plans for one in the Hoffman site.
If the hiss comes from the power stage then it's easier to solve.
  • MAKE LOVE NOT WAR
« Reply #8 on: January 02, 2017, 03:13:33 pm »
Happy new year !
I hate transistors amplifiers but finally I got rid of the hiss problem.
Was coming from de preamp, as I thought. Two tube driver transistors no. 65837 ( 2n3439) defective.
Customer happy, me happy, and year happy.......
I got to develop good troubleshooting methods with transistors. Too often I refuse to repair ss amps cause they scare me to death....
Thanks for the tips.
Jack
« Reply #9 on: January 02, 2017, 05:41:50 pm »
A 40volt poke is WAY nicer than a 400v poke :icon_biggrin:
transistors from an audio troubleshooting point are basically like tubes, signal goes in the middle, comes out the top :laugh:
The older metal ones typically had the "can" as the output, walk your scope can to can til things started looking bad, backup, fix.
new ones, loaded with uP and LSI, SMT, throw out!, no, scrap, they have some gold :laugh:
Offline whoops
« Reply #10 on: January 02, 2017, 08:12:07 pm »
Happy you solved the problem.
You shouldn't be scared of troubleshooting transistor circuits, the same skills apply.
Like shooter said at least is less dangerous than working on a Tube circuit.
The only thing is that normally solid state amplifier circuits can have more components, are PCB based and everything is smaller so it's not as easily accessible as a Turret or Eyelet board with big components.
Unfortunately I don't have an Osciloscope so I use a Signal/Audio Probe, insert music at the input and probe before and after each component. I was able to repair a lot of different amplifiers with this method. I'm sure with an Osciloscope then I would have more options.
Normally in solid state amplifier I find the odd open resistor, or shot capacitor. Hissy or farting transistor, Burned Output transistor.
Sometimes the molex connectors or whatever they're called, the multicable connectors that connect the different pcb's have bad contacts or make intermittent connections, sometimes I prefer to cut the connectors and just solder the wires directly to the pcb's.
  • MAKE LOVE NOT WAR
« Reply #11 on: January 03, 2017, 09:16:25 am »
When i say that ss circuits scare me to death, I mean that replacing small transistors on a new technology pc board is not easy. Fear of overheating the thin copper circuit or close components even with appropriate tools. The old Peavey Mace is much more easy cause at that time the pc boards were more solid and spacey.
Colas leGrippa
Offline Platefire
« Reply #12 on: January 03, 2017, 09:34:26 am »
Just a little info, Gary Rossington of Lynyrd Skynyrd to my understanding uses a Mace to this day that started back in the 70's. I owned one I got new in 79 but never bonded with it---it was heavy as a twin%>/
Glad you got it rolling again. Platefire
On the right track now<><
  • MAKE LOVE NOT WAR
« Reply #13 on: January 03, 2017, 05:12:17 pm »
thanks buddy
