September 08, 2026, 05:45:45 pm
Hoffman Amps Forum image Author Topic: AB763 Single Channel Reverb Only has no headroom.  (Read 5825 times)
Offline 3choplex
« on: December 28, 2016, 11:49:39 pm »
I’d love any input as to why I don’t have any headroom.
I’m building a single channel AB763 Deluxe Reverb using Hoffman’s board and schematic for the most part. Because I am using a princeton chassis (which has one fewer preamp tube), I removed the vibrato circuit. I just connected the bias supply to the power tube grid leak resistors.
I’m using magnetic components iron–the deluxe reverb standard parts. In retrospect, I think the power transformer is overpowered.
The amp works, and it sounds really good, but it has basically no clean headroom. I am assuming it’s because when I pulled the vibe circuit I didn’t adjust any of the other voltages to account for the reduced current load, and because it doesn’t have the normal channel.
Are the high voltages the likely culprit? If so, I suppose I’ll opt for zeners in the B+. Ultimately, I’d be happy if I could get a bit of clean headroom, but less than a stock DR—I wanted a clean amp in the first place, but this sounds so good I don’t want to lose the grind altogether when I turn up.
v1   12ax7
1   Plate 2   204
2   Grid 2   0
3   Cath 2   1
4   H   2.8
5   H   2.8
6   Plate 1   201
7   Grid 1   0
8   Cath 1   1
9   H   2.8
v2   12at7   verb send
1   Plate 2   455
2   Grid 2   0
3   Cath 2   8
4   H   2.8
5   H   2.8
6   Plate 1   455
7   Grid 1   0
8   Cath 1   8
9   H   2.8
v3   12ax7    verb recover
1   Plate 2   196
2   Grid 2   0
3   Cath 2   1
4   H   2.8
5   H   2.8
6   Plate 1   199
7   Grid 1   0
8   Cath 1   1
9   H   2.8
v4 (Tremolo circuit--did not include)
v5   12at7   PI
1   Plate 2   215
2   Grid 2   25
3   Cath 2   81
4   H   2.8
5   H   2.8
6   Plate 1   210
7   Grid 1   28
8   Cath 1   81
9   H   2.8
v6   6V6
1   NC
2   h   2.8
3   Plate   465
4   Screen   463
5   Control   -31
6   NC
7   H   2.8
8   Cathode   0
v7   6V6
1   NC
2   h
3   Plate   462
4   Screen   462
5   Control   -31
6   NC
7   H
8   Cathode   0
Power   5Y3
1   NC
2   465
3   NC
4   350ac
5   NC
6   350ac
7   NC
8   465
Re: AB763 Single Channel Reverb Only has no headroom.
« Reply #1 on: December 29, 2016, 05:09:10 am »
How closely did you follow Hoffman's plan? Refer to Hoffman's preamp schematic. Did you include that 47K resistor just prior to the phase inverter?
Offline 3choplex
« Reply #2 on: December 29, 2016, 09:57:29 am »
I followed it exactly except for 2 changes--the trem circuit, and the first two dropping resistors are 10k.
I have the 47k resistor there.
« Last Edit: December 29, 2016, 10:45:04 am by 3choplex »
Offline 3choplex
« Reply #3 on: December 29, 2016, 11:01:38 am »
The 47k is to replace the 50k intensity pot from the original vibrato circuit, right? Can I just replace it with a 50k pot to use as a master volume and solve most of my problem? (My chassis has holes for 2 more pots anyway.) My thought (which may be wrong) is that a smaller value would allow more signal to ground before the phase inverter, thus the 50k pot?
I saw that you used a 100k pot plus a 220k resistor in your schematic. I assume that the 220k would attenuate the signal as well?
(I also have an older Hoffman layout and schematic that is exactly what I did (I don't see that it's on the website anymore) where the schematic just has the 47k.)
« Last Edit: December 29, 2016, 02:59:56 pm by 3choplex »
Offline 3choplex
« Reply #4 on: December 29, 2016, 05:44:34 pm »
It looks like the schem I used eliminated the 220k mixing resistor. I'll try that next.
Offline 3choplex
« Reply #5 on: December 29, 2016, 10:55:02 pm »
I installed a 250k pot where the mixing resistor would normally be. For the record, 120k seems to be the magic spot for me, but I like the flexibility. It seems like it fixed my problem, but I'm going to live with a few days to make sure.
Thanks, Sluckey, your question about the 47k resistor kind of sent me down the rabbit hole to the solution.
Offline 3choplex
« Reply #6 on: December 30, 2016, 12:12:41 pm »
So on to my next question--the voltages are too high and I'm worried its going to eat 6V6s for breakfast.
My understanding is that if I put a zener on the CT, it's going to cause problems with the bias supply. Is my next best option a zener on the B+, or a mosfet follies kind of arrangement on the CT?
