September 16, 2026, 05:08:10 am
Hoffman Amps Forum image Author Topic: Capacitor testers  (Read 9391 times)
Offline p2pAmps
    • p2pAmps
Capacitor testers
« on: January 05, 2017, 08:59:17 am »
Guys,
I would like some input on capacitor testers.  Right now I have a Atlas ESR tester that works nice on caps 1uF or higher for my purposes.  I want to test for leaking coupling caps.  I know about the Sencore stuff but it is pretty expensive.
What are ya'll using or are you testing in the amp itself under full voltages?
~mike
Everything Affects Everything
Re: Capacitor testers
« Reply #1 on: January 05, 2017, 09:33:44 am »
I use my fluke 87 for basic testing, but don't have anything but the real thing for dynamic testing.
« Reply #2 on: January 05, 2017, 09:52:20 am »
I had access to this cap analyzer for about 30 years. I got bored one day and turned it on!  :icon_biggrin:
http://www.ebay.com/itm/SPRAGUE-TEL-OHMIKE-TO-6-A-CAPACITOR-ANALYZER-TESTED-WORKING-/282310788105?hash=item41bb08c409:g:X9QAAOSw5cNYaUbK
I use a dmm to check for leakage in circuit. Usually have to disconnect one end of the suspect cap.
Offline p2pAmps
    • p2pAmps
« Reply #3 on: January 05, 2017, 10:06:51 am »
That's funny as I am watching that one Steve...
The Sencore LC102 is another but pretty big price tag goes along with that one
I've been using my Fluke 117 like you and lifting one side as well.  Just wondering if I am really getting the whole story or is that good enough and full proof...
« Reply #4 on: January 05, 2017, 10:28:00 am »
I've made out just fine for over 45 years with just a multimeter. I do like having an analog as well as my dmm. And an analog VTVM has advantages as well. Use the dmm to check for leaky coupling caps. Use the VTVM ohm function to check electrolytic leakage or shorts.
Oh, one other thing... I wont spend $10 worth of time obsessing over a $1 cap. If I still have suspicions about a cap after the simple meter checks, I'll resort to the substitution method.
« Last Edit: January 05, 2017, 10:30:51 am by sluckey »
Offline p2pAmps
    • p2pAmps
« Reply #5 on: January 05, 2017, 10:45:21 am »
I'm with you on all accounts Steve.  Lately I've had a run of late 50s tweeds hit the shop and these guys obsess over those old Astrons and such.
« Reply #6 on: January 05, 2017, 08:23:56 pm »
FWIW I use a vintage Eico 950B Comparator. It can put 500V on a cap.  Currently they go for about $50 on eBay.
« Reply #7 on: January 11, 2017, 01:31:44 pm »
I've got a heathkit C-3, probably very similar. Also will put high voltage on the cap. Don't lick it while it's on!
Offline p2pAmps
    • p2pAmps
« Reply #8 on: January 11, 2017, 07:04:23 pm »
I picked up a very mint Sprague Tel-Ohmike TO-6A today.  I figured what the hell, it will be fun and who know, might just catch a bad cab or two...
Offline whoops
« Reply #9 on: January 11, 2017, 10:50:23 pm »
You can use that to reform NOS Electrolytic caps.
If you are using Electrolytic caps that were in storage for 3-5 years, better to reform them before using.
Storage time can be at the warehouse, store, or at your workshop. Basically the time since they've left the factory to the moment  you solder them up.
« Last Edit: January 12, 2017, 01:14:58 pm by whoops »
Offline p2pAmps
    • p2pAmps
« Reply #10 on: January 12, 2017, 09:32:53 am »
You use that to reform NOS Electrolytic caps.
Yes that's right.  Pretty cool box really and so far dang accurate too when I cross test a few things.  Looking forward to spending more time with her when things slow up a tad.
« Reply #11 on: January 12, 2017, 01:04:08 pm »
It's gorgeous!  :thumbsup:
« Reply #12 on: February 07, 2017, 01:54:11 am »
sencore LC53.
Offline p2pAmps
    • p2pAmps
« Reply #13 on: February 07, 2017, 09:48:39 am »
Yeah, love those Sencore LC103 but a little rich for this poor boy
Offline whoops
« Reply #14 on: February 07, 2017, 10:09:47 am »
Hi,
just to let you know I bought this unit some weeks ago just to try it out as it was really cheap.
http://www.ebay.com/itm/Portable-MK328-LCR-ESR-Tester-transistor-inductance-capacitance-resistance-meter-/171927184554?hash=item2807a8a4aa:g:MdoAAOSwk0pVgETb
After using it I must tell you it works great.
On the Capacitor side it measures, Capacitance, ESR and voltage loss after a pulse. The readings I got were spot on with other meters I have.
It also measures transistors, inductors, resistors, Leds.
It's a great a useful overall measuring tool. Highly recommended
