July 30, 2026, 03:28:50 pm
Hoffman Amps Forum image Author Topic: Has anyone had any expereince with the Supro 1624 10 watt transformers?  (Read 5469 times)
Offline silat
It would seem like I could get some loudness from this amp I just built, but I have to put the speaker up to my ear to hear it on the first channel and static out of the other channel. I will try to get pics and more information on voltages today later or Friday.
Offline silat
Re: Has anyone had any expereince with the Supro 1624 10 watt transformers?
« Reply #1 on: January 05, 2017, 02:45:42 pm »
I forgot to mention they are Classictone 40-18062 PT and 40-18063 OT
« Reply #2 on: January 05, 2017, 03:14:34 pm »
Many-many reasons an amplifier won't work right. Why are you thinking transformer?
Offline silat
« Reply #3 on: January 05, 2017, 04:20:23 pm »
Well I called Watts who carry's the layout and schematic and sells  the entire  kit and they said  there were problems. But it may have been just to try and get me to buy their bigger transformers.  Anyhow here soon I will put some pictures. May have  some resister values wrong. Thanks for answering PRR.
Offline silat
« Reply #4 on: January 05, 2017, 04:48:35 pm »
Here are some pics.
Offline silat
« Reply #5 on: January 05, 2017, 04:50:42 pm »
Some more...
« Reply #6 on: January 06, 2017, 04:35:28 am »
Is this the schematic you used ?
Did you used the expensive 6973 as power tubes ?
Offline silat
« Reply #7 on: January 06, 2017, 09:42:48 am »
Yes Franco, I did use those as power tubes. Is there a problem with them? Is there an alternative if so and I can use the same transformers?
« Reply #8 on: January 06, 2017, 01:07:34 pm »
I was asking because who is able to help you is eased on doing it knowing the exact schematic you used
That because I've seen a 6v6 version here
https://www.thegearpage.net/board/index.php?threads/amp-build-thread-supro-1624t-type.1758490/
Offline silat
« Reply #9 on: January 06, 2017, 02:24:41 pm »
  Thank you for that. That is interesting... I will compare the two and see if I can make out what the differences are besides the obvious 6V6's in place of the 6973's....
« Last Edit: January 06, 2017, 02:26:43 pm by silat »
Offline silat
« Reply #10 on: January 07, 2017, 07:57:18 pm »
I have it playing strong and loud now on the first channel. It was a grounding issue. :BangHead: The other channel I am going to work with and make it a little cleaner and stronger.
« Last Edit: January 07, 2017, 10:03:33 pm by silat »
