September 16, 2026, 12:04:01 am
Hoffman Amps Forum image Author Topic: I SHOULD KNOW THIS!!!!!! Separate bias winding.  (Read 4433 times)
Offline Blind Lemon
  • Do you smell something.....OH Crap! It's smokin'
« on: January 10, 2017, 05:15:32 pm »
Independent bias winding< ground one lead and the other is the supply? I am either brain farting or I have never run across this before.
I am thinking it is the first and not the second.  :think1:
BL
Re: I SHOULD KNOW THIS!!!!!! Separate bias winding.
« Reply #1 on: January 10, 2017, 06:33:11 pm »
Yes, if you will do a typical single diode supply.
Depending on the winding AC voltage and your desired bias voltage, you may need to use a full wave bridge. In this case you would not ground one of the winding leads.
Offline Blind Lemon
« Reply #2 on: January 10, 2017, 09:15:04 pm »
It's a 95 volt winding so a one diode supply should do.
Thx
BL
