September 17, 2026, 08:40:52 am
Hoffman Amps Forum image Author Topic: Small NOS OT - Question  (Read 10045 times)
« on: February 01, 2017, 12:56:03 pm »
Reading the Silvertone 1449 thread we have talk about the OT, so I remembered that a friend give me, some time ago, a small NOS NIB OT
and looking to it it is exactly 7K primary 3.2ohm secondary
the core is 17mm x 18mm
The measures are:
Large 54mm - Tall 46mm and the OT weight is 350 grams
wires seems to be 0.5-0.6mm diameter
(sorry for the decimal measures instead of imperial)
Do you think it can be used for a Champ or the OT is too small ?
How many W can I consider it is rated ?
« Last Edit: February 01, 2017, 01:42:10 pm by kagliostro »
Re: Small NOS OT - Question
« Reply #1 on: February 01, 2017, 01:23:53 pm »
> weight is 350 grams
Compare with similar parts. I looked in Hammond. 350g is 0.66 pounds.
1750C Output 7W Champ 4.00 lbs
1750B Reverb Driver - Vibro King (6V6/6BQ5 @ >400V) 10W 1.00 lbs
1750A Output 3.5W Fender 12AT7 Reverb Driver 0.40 lbs
Weight also goes with bass response. The ssame iron might do 8W clean at 160Hz but 2W clean at 80Hz. This is probably why the "10W" reverb driver is smaller than the "7W" loudspeaker driver.
So I do not know what to say. It may be several Watts if there is not much bass, sub-Watt with heavy bass.
« Reply #2 on: February 01, 2017, 01:43:38 pm »
use it for 6BM8/ECL82 reverb tank driver.
« Reply #3 on: February 01, 2017, 02:17:29 pm »
Many Thanks PRR & DummyLoad
Looking to the measures of the 1750A seems this can be a 4 - 4.5W OT
I was thinling to ask for a tube and B+ to use it
and the ECL82 @ 272V on 8K gives 3.5W ..... very good !
There is a single tube that can be a sub for the ECL82 pentode for the use with this OT ? 6K6 ? Others ?
« Reply #4 on: February 01, 2017, 03:03:19 pm »
use a 6V6. :-)
--Pete
« Reply #5 on: February 01, 2017, 03:16:15 pm »
 :icon_biggrin:  THANKS
OK, but you must explain me a thing
6V6 with 315V B+ give 5.5W on a 8.5K load
5.5W is a bit high respect to the estimated power of the OT
which is the right way to tame the power ?
a lower B+ (remaining on that "high" load value) or cathode resistor adjust ?
« Reply #6 on: February 01, 2017, 03:44:32 pm »
drop B+ and drop idle current. use a 6K6 and you'll be right where you want to be with 250V B+. without the specs of max bias current allowed for that transformer, you're really shooting in the dark. tune the driver so the output doesn't make 5W. use the ECL82 - should still plentiful in EU.
another thing to consider is that pics show that it's 7.5K ohm into a 3.2 ohm load - so 8 ohm tank load will be about 17K anode load.
« Reply #7 on: February 01, 2017, 04:05:57 pm »
Grazie ancora Pete
« Reply #8 on: February 01, 2017, 04:12:36 pm »
Power goes as Square of voltage.
272V/315V is 0.86. 0.86 squared is 0.75. 0.75 times 5.5W is 4.1 Watts. Not so different than the 3.5W claimed.
_I_ think you should be nearer 200V and couple-Watt expectation. You can still use 6V6 at this level. It's like using a Chevy V-8 in a small boat. It is readily available cheap and is not strained.
Same as Right way to play. With your teeth. On fire. Upside down.
« Reply #9 on: February 01, 2017, 04:24:00 pm »
Grazie PRR
unfortunately I'm not able to play  :icon_biggrin:
Pete told 6V6 and I replied 6V6 but I was thinking 6П1П or 6AQ5
« Reply #10 on: February 01, 2017, 10:30:03 pm »
Grazie PRR
not really that critical what tube (9pin 7pin, small 8pin, etc.) you use with that OT. with 250-300V B+ with that load will work just fine. just bias accordingly. calculate max Pdiss, estimate bias point with datasheets and calculate Rk. start higher, work your way down to Pdiss ~~=80-90% max Pdiss.
EL95 is your EU 6AQ5 equivalent.
« Reply #11 on: February 01, 2017, 11:14:59 pm »
And 6AQ5 is just a small 6V6. Ratings a bit lower.
But if you have a 5W Pdiss 250V pentode you can use it.
Even (ahem) two parallel 6AU6 or other sharp-cutoff radio IF tubes.
« Last Edit: February 02, 2017, 12:52:22 pm by PRR »
Offline trobbins
    • Tim's projects and info
« Reply #12 on: February 02, 2017, 12:52:24 am »
K, can you see the laminations enough to check if it is layered up as a transformer or with some air-gap?
It 'looks' like 7k PP with CT from wire size and assuming a single secondary winding.
Do you have enough test gear to check primary PP inductance - eg. apply 12VAC across primary from mains transformer and measure AC current ?
« Reply #13 on: February 02, 2017, 03:15:38 am »
Ciao Tim
I can't say if there is an air-gap because laminations (as far as I can see) are a kind of F laminations not the more standard E-I laminations
they are something like this (I can't see the core ofcourse)
So, if there is an air-gap it can't be seen
I'm 99.99999% sure it is an SE OT, you see 3 connection on the primary because the transformer has a part of the primary devoted to act like an incorporated choke, I've seen this configuration on many old recorder, radio and record player, yesterday I measured the resistance but today I didn't remember the values (the whole primary is  around 400R and the real primary is around 370R - the "choke" is the difference), the secondary is single so, 2 connections only
See this Grundig Como (Stereo Radio) schematic
I've an impedance meter, but don't know if the measure is on the range of the instrument, I'll try and report to you
.... apply 12VAC across primary from mains transformer and measure AC current
This is necessary anyway or only if the impedance meter is out of range for the measure ?
(12VAC to the primary I suppose and no load on secondary ..... or you mean something other ?)
« Last Edit: February 02, 2017, 03:24:13 am by kagliostro »
Offline trobbins
« Reply #14 on: February 02, 2017, 06:07:02 am »
The old way to measure primary winding inductance was to measure the AC current (down at the 100uA to mA level) using a mains frequency low voltage supply - circa 5 to 20VAC - then use V = I.Z.  That is a much better way to measure transformer inductance, as the applied voltage affects the inductance level, and some inductance meters just use a low voltage level.  I guess you may measure something greater than 10H if there is no designed in gap.  And yes, all other windings are open.
Measuring turns ratio and checking if the impedance ratio is correct would be a good idea - but best to apply a voltage across the 'choke' part of the winding, so you get better accuracy of the 'primary' and secondary windings.
« Reply #15 on: February 02, 2017, 07:33:51 am »
OK, summarize
Label say:
Measures are:
core is 17mm x 18mm
Resistance Measures: (Measured with a specific ohm meter, not the usual tester)
Primary ~395ohm - "Choke" ~16ohm - Total resistance ~410R
Secondary 0.395ohm
Impedance:
Primary 6.93H - "Choke" 10.39H - Total 7.46H
Secondary 4.31mH
Current flowing on windings (at 14.3V):
Total (Primary + "Choke") = 2.43mA
Primary = 2.58mA
Same measure with one other tester
Total (Primary + "Choke") = 2.44mA
Primary = 2.61mA
"Choke" = 0.59A (voltage Drop from 14.3V to 13.3V - the 12V PT I used is rated at 20VA)
Voltage Measures:
14.3v on Primary = 348.7mV on secondary
14.3v on Primary + "Choke" = 336.5mV on secondary
8.40v on Primary Secondary = 320v on Secondary Primary
8.38v on Primary + "Choke" Secondary = 331.1v on Secondary Primary + "Choke"
Impedance measured with CESVA MPI-3 (Line impedance meter):
3.2R resistor connected to secondary = 7K11ohm on Primary (measured at 1000Hz)
Are this data useful to understand better the spec of this OT ?
« Last Edit: February 03, 2017, 12:52:38 am by kagliostro »
« Reply #16 on: February 02, 2017, 10:32:21 pm »
8.40v on Primary = 320v on Secondary
is that reversed? 320V on primary 14.3V on secondary?
as already stated: you have a 2-3 watt part based on the dimensions.
for reverb, copy a fender AB763/6G15 driver and recovery. use your transformer with an 8 ohm tank.
or build PRR 1/3 watt with 8 ohm load. <<<  :icon_biggrin:
« Reply #17 on: February 03, 2017, 12:58:52 am »
Thanks Pete
I corrected the post (it was 8.40v - 8.38v on secondary, the PT I used is only 20VA and the voltage dropped from 14.3 till 8.38 with that load)
OK for the W of the OT and for possible uses, the data I posted were in response to Tim questions/suggestions
Nice idea also the 1/3W
« Last Edit: February 03, 2017, 01:01:39 am by kagliostro »
Offline trobbins
« Reply #18 on: February 03, 2017, 01:00:15 am »
K, I think a few of the reported values need some 'corrections'.
I have assumed your mains is 50Hz.  If you have 14.3Vac across the total primary winding (choke + pri), and measure 2.44mArms through the total winding, and have 410 ohm total resistance, then the total inductance is about 9.3H.
If you have 14.3Vac across just the 'primary' part of the primary winding (not including the choke), and measure 2.58mArms through the total winding, and have 395 ohm resistance, then the total inductance is about 8.8H.
If you put 14.3V across just the choke part of the winding, then that's not good, as you have saturated the choke and may well melt the wire  :sad2:
The 'choke' portion of the total primary winding is then about 9.3 - 8.8 = 0.5H.
It is going to be a bit tricky to get a good impedance ratio measurement.  Using just the primary voltage of 14.3 and .3487V on secondary, gives about 7K to 4.2 ohm ratio.  But the magnetising current in the primary winding introduces a small error.  My only suggestion (if you are keen) is to apply a low voltage like about 3.15VAC (or something easy to get on the bench) across just the choke portion, and measure the AC voltage across just the 'primary' portion (not including the choke), and across the secondary - that will remove the magnetising current from the windings of most interest.
« Last Edit: February 03, 2017, 01:02:31 am by trobbins »
« Reply #19 on: February 03, 2017, 01:05:56 am »
Ciao Tim
I'll look for a ~3V AC source, then I'll try again
« Last Edit: February 03, 2017, 01:55:55 am by kagliostro »
Offline trobbins
« Reply #20 on: February 03, 2017, 01:32:54 am »
6.3VAC heater with CT will give you 3.15VAC nominal  :icon_biggrin:
« Reply #21 on: February 03, 2017, 01:56:49 am »
Yes, I'll find one (I've more of one for sure)
« Reply #22 on: February 03, 2017, 05:16:59 am »
Here I'm Tim
I connected 3.4V to the "choke"
there were 150.2mA flowing on the "choke"
I connected the Amperometer to the primary pins and there was a current of 7.6mA flowing
I connected the Amperometer to the secondary pins ant there was a current of 173.3mA flowing
(I hope I didn't do something wrong ???)
Offline trobbins
« Reply #23 on: February 03, 2017, 06:49:31 am »
That test is for voltage on the windings, which then allows the turns ratio to be calculated, and hence the impedance ration.
« Reply #24 on: February 03, 2017, 11:25:52 am »
My only suggestion .......  is to apply a low voltage like about 3.15VAC ...... across just the choke portion, and measure the AC voltage across just the 'primary' portion (not including the choke), and across the secondary - that will remove the magnetising current from the windings of most interest.
So I was wrong, I measured current instead of voltage :l2: :l2:
OK I'll do that one other time
« Reply #25 on: February 03, 2017, 04:33:23 pm »
@ Tim
This are the new measures
3.5v on "choke" = Secondry 1.158v - Primary 47.5v
3.5v on Primary = Secondary 87mV
3.5v on Primary + "choke" = Secondary 84mV
3.5v on Secondary = "choke" + Primary 149.8v - Primary 144.5v
Ciao
Offline trobbins
« Reply #26 on: February 03, 2017, 06:13:21 pm »
K, there is a spreadsheet (if you have MS Excel or a converter) to assist inserting the values and doing the calcs at:
http://www.dalmura.com.au/projects/OT%20calcs.xls
The 47.5 and 1.158V measurements indicate a 7k to 4.2 ohm ratio.
The 144.5 and 3.5V measurements indicate a 7k to 4.1 ohm ratio.
The 149.8 and 3.5V measurements indicate a 7k to 3.8 ohm ratio.
If you don't want to use the original configuration, then you could use the entire primary winding as an SE primary.   But you may find there is a benefit from using that choke portion, as it biases the core to allow more SE primary winding flux swing so you may notice a better low frequency response, and/or use it for a higher power output.  A quick calculation of ampere turns in the SE primary and in the choke portion of the winding would indicate how much 'bias' actually being achieved, as it may be practically insignificant.
If you have an SE output stage wanting 7k primary (eg. 5-10k range) then 4 ohm speaker is easy - you could also use an 8 ohm speaker if you needed higher than say 10kohm primary impedance.
« Last Edit: February 03, 2017, 06:16:32 pm by trobbins »
« Reply #27 on: February 03, 2017, 06:47:38 pm »
Thanks for all this info
And for the xls file link  :thumbsup:
I'll read all slowly later, now are 01:45 AM here, bed reclaims me
Grazie
Offline Raybob
    • Tube-Tone Amplifiers
« Reply #28 on: February 03, 2017, 08:30:30 pm »
> weight is 350 grams
1750A Output 3.5W Fender 12AT7 Reverb Driver 0.40 lbs ...
Wonder why Hammonds are so heavy.  I have a Fender replacement OT for Fender Champ from CE Dist. that weighs 0.6 pounds.  It's a little larger than a reverb driver.
« Last Edit: February 03, 2017, 08:32:33 pm by Raybob »
« Reply #29 on: February 03, 2017, 10:13:49 pm »
> 0.6 pounds.
I was wondering also. 4 pounds seems like a lot for a cheap amp.
So maybe K's OT is a near Champ.
