September 18, 2026, 01:57:49 pm
Hoffman Amps Forum image Author Topic: Amp sounds horrible  (Read 6382 times)
Offline fossilshark
  • No life til' leather
Amp sounds horrible
« on: February 22, 2017, 08:34:32 pm »
Ive been working on this build for a few months and i just got sound out of it. Theres absolutely no sound (no noise no ambience) coming out of the speakers until i play a note then it kind of sags and fades out. I thought mabey there wasnt enough signal but my distortion pedal had no effect. The weirdest part, when i turn it off you can heard my hands on the string and the feedback for a split second and it shuts off. Does this sound like the plate voltage is too low? Ill take some readings and post them here.
~SNOWBLIND~
Offline fossilshark
Re: Amp sounds horrible
« Reply #1 on: February 22, 2017, 08:44:45 pm »
When i measure the voltage it wont stop rising
~SNOWBLIND~
Offline p2pAmps
    • p2pAmps
« Reply #2 on: February 22, 2017, 09:24:03 pm »
Detailed pictures would be helpful
Everything Affects Everything
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #3 on: February 22, 2017, 11:36:20 pm »
Also the schematic of the amp can help !
https://soundcloud.com/ukiuki
Offline hesamadman
« Reply #4 on: February 23, 2017, 09:43:53 am »
Does it act as if there is a heavy noise gate? Like if you barely hit the strings there is no sound but if you pluck them good there is a sound but with a very fast decay?
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #5 on: February 23, 2017, 09:52:36 am »
As others have mentioned, if we don't know what 'kind' of amp and don't have a schematic, it becomes impossible to even guess intelligently.  Also, pictures of the amp will help us look for things in the schematic that don't match on the actual amp.
Phil Davis
tUber Nerd =|D
Offline MFowler
« Reply #6 on: February 23, 2017, 10:04:27 am »
You need to go over your schematic/layout against your amp to see if it is wired correctly and measure every resistor. I usually check resistor values with DMM before I wire them in and when I don't I find that I have mistakenly inserted a 100 ohm for a 100k (example) and no sound or gated sounded happens.
Hello Phil (pompeiisneaks)
Mark
    • Daviszone
« Reply #7 on: February 23, 2017, 11:25:24 am »
Mark
I see you've come over to the dark side :)  or is this the light?  I'm not so sure lol
Phil Davis
tUber Nerd =|D
Offline fossilshark
« Reply #8 on: February 23, 2017, 11:49:39 am »
I made a dummy, plate voltage was too high. I was using the wrong transformer line for tha plate voltage
~SNOWBLIND~
    • Daviszone
« Reply #9 on: February 23, 2017, 12:45:34 pm »
Is this some kind of multi tapped Transformer?  usually the highest voltage output is the one for the plates.  ?
~Phil
Phil Davis
tUber Nerd =|D
Offline fossilshark
« Reply #10 on: February 24, 2017, 12:23:47 am »
Yes its really weird theres a 700v line with a few center taps with different voltages like 280v and 390v
~SNOWBLIND~
    • Daviszone
« Reply #11 on: February 24, 2017, 02:42:19 pm »
OH ok, gotcha, possibly an UL transformer, I think they do have two sets of taps for UL mode or some such.
Phil Davis
tUber Nerd =|D
