September 08, 2026, 12:18:48 pm
Hoffman Amps Forum image Author Topic: SS Gyrator (Choke) Question about (References to Merlin's circuit but not only)  (Read 14834 times)
As far as I can understand, choke value in Henry is better if it is the higher possible
What impede the use of large Chokes (in Henry) is the weight, the resistence and the cost of this devices
because high Henry values call for large resistance value or high weight & price
I would like to know if a high value SS Gyrator (that has for sure a low resistance value if compared with real chokes)
can be considered a good thing also in project (like some guitar amps) that uses 10H - 15H or lower value chokes
On Merlin's PS book there are explanations about a SS Gyrator version of the wrapped chokes
this circuit can be build on the cheap and in a very small space, friends that have tried it are satisfied
also someone has simulated the circuit and say that also if it isn't a real SS Gyrator/Choke emulator, the circuit do his job
On Merlin's book there is a formula to calculate the values in Henry and in Resistance of the circuit
but the formula seems to apply correctly only to the H compute
The circuit to which I refer is this
So I would like to know your opinion about the fact that in practice, the value that interest is the Henry value (the higher the better)
being the resistance value a secondary aspect if it is low enough to don't affect much the B+ value
I hope I was able to explain adequately what I mean
Thasnks
Frasnco
Show your math.
Formula for R is simplified. It should include Rgs of the MOSFET with R3. To compute Voltage Drop it should include VgsOn of the MOSFET. But for any practical case, these errors are quite small. Use the formula and assume the real voltage drop may be up to double. The values shown give R of 20 Ohms. At 250mA this is 5V drop. In real life I might expect 10V drop. This difference is usually insignificant.
The major "flaw" of this "choke" is that it can not kick-up higher than the input voltage. If the right side goes to a large capacitor, as for B+ filtering, we do not expect (and do not want) much kick-up. It does not work (as shown) as an audio plate-load like a real choke could.
Hi PRR
Show your math
My math says 10R
10R (R3) : [1 + (47000 (R1) : 47000 (R2))]
47000 : 47000 = 1
1 + 1 = 2
10 x 2 = 20
so 20R and not 60R as shown
instead
100uF x 47000R x 10R
100 x 47000 = 4,700,000
4,700,000 x 10 = 47,000,000 That I can assume as 47H as shown
So Henry OK but Resistance  :w2:
However, as you say, there is an insignificant drop in voltage and this, I think, is positive
OK
OK
this two things I think I've understand
here I didn't understand exactly what you are trying to explain me  :dontknow:
I've a graph (if it can be of some use)
Thaks PRR
« Last Edit: February 24, 2017, 01:22:46 pm by kagliostro »
> not 60R as shown
Ah, I missed that.
Had a long struggle with the sim. Actually a long struggle with an idiot brain which forgot to put in the 10 Ohm resistor. Works a lot better when all the parts are there.
I essentially confirm Merlin's graph. His formula for "L" is in a correct form but the result is a bit better than calculated (calc=47H, acts-like=55H). His formula for "R" is obviously simplified to neglect MOSFET Gm and Vto. These omissions sorta complement each other if the drop on the "10 Ohm" resistor is a few Volts, which would be a good operating point.
We both show a resonance near 3Hz, which with 47uFd says 60H (a wee bit higher than the formula or the sim says). We both show -20dB near 10hz. My sim levels-out at -40dB while his levels-out below -65dB.
This makes sense. I modeled an IRF150, a very old HIGH-current (38A!) device with a Gate as wide as a drive-way and correspondingly huge Gate capacitance. With Miller there may be most of 1uFd stray C, which with a 100uFd Gate clamp cap is just -40dB. His MOSFET is surely more right-size, with less stray C, and deeper level-off.
Here are the effective DC resistances I simmed:
30r @ 697mA
45r @ 240mA
82r @ 97mA
261r @ 24.5mA
Note that the "worst" of these is only 6.4V loss. At very high current I sim 21V loss, 11V at nominal 240mA.
I also plotted a perfect 55H + 47uFd filter, which lays almost exactly on the higher parts of the Gyrator filter (excluding the odd peak).
> the odd peak
The "odd peak" is just loading. If the load is 1.2K (300V and 250mA) the peak is 1dB, just like the real choke. After my sim-struggle I grabbed a plot of the gyrator loaded with 12K, which does reasonably show a peak. At design 250mA tube-amp load the 3hz bump will be minor.
Many tahns for the simulation PRR
I really appreciate your effort  :worthy1: :worthy1:
Only one question, if possible
Few time ago you give me a council about a voltage dropper for G2 supply using an STP6NK90Z
So now I've in stock some STP6NK90Z, are this usable for this gyrator or is better I get some IRF820 ?
> STP6NK90Z
Fine.
Many Thanks
