September 18, 2026, 08:46:08 am
Hoffman Amps Forum image Author Topic: 2-2.5W (estimated) - 3K / 4ohm PP OT ...... any idea for a use ?  (Read 5290 times)
« on: February 25, 2017, 06:31:14 am »
Today I got this small OT (hoping it will be for SE, but getting it anyway because cheap and new)
it is a Stelvio an old italian brand, 3000ohm primary / 4ohm secondary 2-2.5W (estimated power)
if it was for SE I had an use for it, but it is PP ...........
any idea of which can be the right tube for this OT ?
Re: 2-2.5W (estimated) - 3K / 4ohm PP OT ...... any idea for a use ?
« Reply #1 on: February 25, 2017, 11:10:22 am »
Maybe I'm wrong and this is not a push-pull transformer
I came to doubt whether it's an SE transformer with a primary side to feed the G2 (but not UL), I have to do some testing
« Reply #2 on: February 25, 2017, 11:19:08 am »
Back in the '60s it was very common for small, cheap single ended OTs to have a tap (not UL) for screens.
« Reply #3 on: February 25, 2017, 11:41:32 am »
Ciao Steve
One of the things that suggested me for a PP was the way the laminations are assembled, but looking better to the OT the doubt come to me
and I can say something further only after some test
I've also the doubt that this thing can be planned for a transistor unit output (???)
« Reply #4 on: February 25, 2017, 11:59:46 am »
A 3000Ω primary is not likely for a transistor. If I had this many doubts I'd probably put it in the trash.   :icon_biggrin:
« Reply #5 on: February 25, 2017, 12:59:26 pm »
 :icon_biggrin: :icon_biggrin:
Is a bit of time that I look for a small SE OT with 3 - 3.5K primary, it seems is the good match for a 6AF11 project like the Squirrel Monkey
I've 2 or 3 tubes and a pair of sockets ...........
Sure if it was a PP would not know which tubes can be adopted, but let's wait until we see what it is
Offline frankenxtein
« Reply #6 on: February 25, 2017, 08:08:51 pm »
If it's reflective would a 8ohm speaker make it 6k ?  :think1: A fiddle tube amp. I was reading smaller OT's have better high frequency response , I was going to tweak one of these little amps here for electric violin.
