September 08, 2026, 01:12:00 pm
Hoffman Amps Forum image Author Topic: 1 watt Marshall  (Read 47216 times)
1 watt Marshall
« on: March 05, 2017, 08:32:41 am »
There is a 27 page thread on the Amp Garage about this amp.  I've not built it and have no current plans to.  I took the most "current" schematic they posted on the thread and redrew it in a way that was easier for me to follow.
http://ampgarage.com/forum/viewtopic.php?f=9&t=24671&hilit=JTM1+1W+Marshall&start=390
I don't know if this is a "proven" idea or not?
Discovered from the guy that drew up the schematic that 56k is correct for the grid to cathode on the phase invertor.
« Last Edit: March 12, 2017, 06:55:04 pm by tubenit »
Offline smackoj
Re: 1 watt Marshall
« Reply #1 on: March 05, 2017, 11:58:03 pm »
Thanks for your effort Tubenit. It seems to me that building an amp with what looks like a lot of time and energy invested, doesn't really compute to only produce 1 watt of power for use. Just one old man's opinion mind you.
Re: 1 watt Marshall
« Reply #2 on: March 06, 2017, 02:00:46 pm »
Here is a YouTube that is a 1 watt Marshall.
https://www.youtube.com/watch?v=w71tBeuLn2Y
! No longer available
CHECK for ERRORS with this layout!  Compare with schematic.  IF there is a discrepancy, then go with the schematic.
« Last Edit: March 06, 2017, 03:04:39 pm by tubenit »
Re: 1 watt Marshall
« Reply #3 on: March 06, 2017, 04:49:07 pm »
OK,  I think IF I were to try and build this, I'd use this schematic and layout.
CHECK for ERRORS!  Compare layout with schematic.  IF there is a difference, then I'd go with the schematic.   This is a DRAFT design!
Musical Power Supplies has a 5 watt push/pull OT for use with 12AU7 power tubes.
http://www.ebay.com/itm/OT5PP-Push-Pull-Tube-Output-Transformer-Low-Power-22K5-4-8-16ohm-5VA-Imported-/152426606383
This PT might work but you'd probably need a larger dropping resistor between node B and node C on the B+ rail?  190-0-190
http://www.ebay.com/itm/PT190-2-USA-POWER-TRANSFORMER-TUBE-AUDIO-380Vac-190-0-55-190-x120mA-/162017736572
« Last Edit: March 13, 2017, 07:16:06 am by tubenit »
Offline jerrydyer
  • Make it one of a kind
Re: 1 watt Marshall
« Reply #4 on: August 29, 2018, 03:24:07 pm »
Anyone have the jmp1h schematic. I havr low low volume.
Re: 1 watt Marshall
« Reply #5 on: August 29, 2018, 08:40:34 pm »
um, original post, 1st image should get you close enough to fix
Offline Ampmod
Re: 1 watt Marshall
« Reply #6 on: January 15, 2022, 10:52:43 am »
I see no One answered this so Far, 56k Ohm resistor is OK, because it is "bootstraped" and ir does not make load at stage before it.
P.S. Schematic with drawed DC voltages on Phase Inverter is worg. R16 and R11 are Equal resistors, current through them is the same. But showen Voltages Drops very different (42V and 29V); it is wrong.
Re: 1 watt Marshall
« Reply #7 on: January 15, 2022, 03:17:56 pm »
 :BangHead:
« Last Edit: January 19, 2022, 03:02:11 am by shooter »
Offline voodoochild2b13
Re: 1 watt Marshall
« Reply #8 on: January 24, 2022, 07:39:32 am »
hello i get that schema from another forum. it made by mattec.
i home it Will help somebody. sorry for my english
Offline distortionhead
Re: 1 watt Marshall
« Reply #9 on: January 24, 2022, 11:11:22 am »
