September 15, 2026, 11:46:56 pm
Hoffman Amps Forum image Author Topic: What do pedal makers use to "Goop" the circuit board and devices?  (Read 10078 times)
Offline smackoj
I just finished a Soldano SLO-100 (preamp section) clone pedal. This project started out from a pcb I bought from the OLC (Officially Licensed Circuits) Company. It is a small enough board but after adding 5 off-brd pots and connecting wires, I am leery of metal to metal contact inside the box. I would like to use some 'goop' like the big boys use or anything that someone might suggest. There are a couple spots on the top side (parts side) that need a dab before I close the lid. I will probably wedge a piece of cardboard in between the back of the pots and the solder side of the board?
Thanks amigos.
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: What do pedal makers use to "Goop" the circuit board and devices?
« Reply #1 on: March 06, 2017, 07:06:55 pm »
Most people, be they amp makers or pedal makers that 'goop' the amp do it to 'hide' the mojo of the device from peekers.  If you're just trying to protect shorts, I'd suggest putting a little GE Silicone II on any bare leads that worry you.  That reduces vibrations anyway, and protects them from grounding, as well as leaving the components visible for later maintenance etc.  If you goop it and something goes wrong, throw it away and build another ;).
You could also just layer the chasiss in that area with silicone to protect from grounds and not touch the board.
BTW don't use Silicone I it has acid that will etch the components and can ruin them, thus why I suggested using II.
~Phil
Phil Davis
tUber Nerd =|D
Offline smackoj
« Reply #2 on: March 07, 2017, 12:58:02 pm »
I thought about silicon but did not know info like specifically using the II variety. Thanks. I have always liked silicon but don't like the long dry time. It's a trade off like most things.
Good suggestions.  thx
Offline BetterOffShred
  • I play tube amps..
« Reply #3 on: March 07, 2017, 01:43:09 pm »
Hot glue works fine for stuff you don't want to move around.  You can also use Epoxy to glue in some standoffs and screw the board to them.
-Brett
« Reply #4 on: March 09, 2017, 02:13:10 pm »
Hi OJ,
I generally like to face the board the other way and then use some packing sheet foam to insulate between the board and the bottom of the enclosure. This works well this way without epoxy and a couple zip ties helps keep things in place.
Offline smackoj
« Reply #5 on: March 10, 2017, 10:33:37 pm »
Looks nice JoJo.  I do mounts like that too but this SLO clone has 4 trim pots that I want to be able to access easily. I would certainly like to get rid of all the pot wires looped over the edge of the pcb.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #6 on: March 30, 2017, 07:55:11 am »
How about some insulation tape over the pots ? It is easy to remove and replace if needed.
https://soundcloud.com/ukiuki
