September 08, 2026, 09:06:23 pm
Hoffman Amps Forum image Author Topic: Limited B+ with a VVR - Which is the way to calculate the resistor ?  (Read 4547 times)
A simple VVR we use is this
The 47k resistor set the lower voltage that can be reached
if we want we can add one other resistor between B+ and the pot to drop the higher voltage that can be reached rotating the pot to the max
I don't know how to establish the value of the added resistor, so I've think to the sum of resistor + pot as a resistor voltage divider
I did a bit of math and to me seems that around 420K will be a good value for that resistor
(assuming 350V B+ and 250V the max voltage to have on the output)
Can I consider that as the right way to calculate that resistor ?
« Last Edit: March 09, 2017, 05:10:43 pm by kagliostro »
Re: Limited B+ with a VVR - Which is the way to calculate the resistor ?
« Reply #1 on: March 09, 2017, 03:35:35 pm »
That's the right answer (actually 418,800Ω), so I assume you did it correctly.
« Reply #2 on: March 09, 2017, 05:11:19 pm »
Many Thanks Steve
