July 25, 2026, 09:08:24 am
Hoffman Amps Forum image Author Topic: Can I use 2 different EL84s in a Fender Blues Jr.?  (Read 4053 times)
Offline TerryD
« on: March 18, 2017, 07:51:12 pm »
I sold this to a friend.  He cracked up the PCB board with the electrical cord.  I had to replace the O.T.  I did point to point around the power tubes and scraped the PCB board connections.  Seems to be working.  I sold him the unit with 2 RCA EL84s.  One bit the dust in this scenario.  I have one  Fender GT EL84.  I've been running the 1 RCA and the 1 GT EL84s.  I don't see a problem with this thing cranked for 10 minutes.  Both tubes seem to be running the same, glow wise.  Sounds goodt.
Any problem giving it back to him with this power tube configuration??
Thanks a lot for the help fixing this up and for the reply to this,
Terry
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Can I use 2 different EL84s in a Fender Blues Jr.?
« Reply #1 on: March 18, 2017, 07:57:37 pm »
Take readings from the power tubes pins and post it, the gurus might shine in, and then they will be able to tell you how's it going to be in the long run. You might need to balance the bias between the 2 different tubes.
« Last Edit: March 21, 2017, 10:57:01 pm by uki »
https://soundcloud.com/ukiuki
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #2 on: March 18, 2017, 11:53:35 pm »
Using two different tubes will work just fine, but if they're not balanced it can add unwanted noise since either side of the push/pull would be imbalanced, but everyone out there has different ear sensitivity, you may not notice a difference.  it definitely can't hurt anything, it may just be a bit unbalanced.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #3 on: March 19, 2017, 01:29:56 am »
Different brand didn't signify that tubes can't be used together
if they bias correctly and the bias of each tube isn't so different eachother
