September 19, 2026, 05:46:27 am
Hoffman Amps Forum image Author Topic: 6 of one, or half dozen?  (Read 4337 times)
« on: March 20, 2017, 05:14:57 pm »
Couple questions;
I have a 470 then 2K dropping R’s in the PS,(breadboard tweaking), since there is no tap, should they be 1K 1K, 2K then 470, makes NO difference?
I want Rg to fall somewhere between 220k – 470k per tube.  Can I use a single Rg for all 4 tubes, or is it “better” for each grid to have it’s own R? Designing as Audio only.
Re: 6 of one, or half dozen?
« Reply #1 on: March 20, 2017, 05:30:52 pm »
It will BE a single resistor for all four, because the grids are all directly connected. Using four 500K is a waste of 17 cents compared to one 125K.
I would use one 100K.
2K looks like a lot of B+ drop for a power amp. The load for four 6K6 ought to be like 8K each, so 2K total. Well-biased (which it appears to be) it wants to suck around 140mA(!). That's a huge drop in 2K.
« Reply #2 on: March 20, 2017, 09:00:34 pm »
one 125K.
1 Resistor it is
It is, here's my breadboard #'s for 1 tube, although all 7 were within +-20%
Orig B+ after bridge 336Vdc, as drawn 271 at plate
Vk 18.3  Ip .033A  Pdiss 8.41  OT impedance ~~~8750.  I got there with a 5K:8, took the 8 to 14 then mathed this(14 / 8 =1.75 * 5000)), not sure if that is fuzzy math or not :dontknow:
