September 18, 2026, 08:43:10 am
Hoffman Amps Forum image Author Topic: Fender pro 300 farting  (Read 5225 times)
Offline pbman1953
« on: March 24, 2017, 09:42:59 am »
I have a Fender Pro 300 - 300 watt tube amp. Recently after using, for about 10-15 minutes, it starts to fart/sizzle with each note. The sound goes up and down with the volume control. I've even swapped caps to eliminate speakers. The sound went to the other cab swapped with o it's the amp.
I have a newer set of JJ -6550's which have been fine. When this happens there is a significant loss of power.
I made some some tests because each pair of tubes has a fuse next to it and the fuse can be pulled to take them out of the circuit. I've run each set alone and could not duplicate the sound.
I know I'm the early stage of detection but was wondering if my story rings any bells.
Here's the manual- It shows Sunn but all Fender did was change the nameplate.
http://www.sunnamps.com/pdfs/manuals/bass/300T.pdf
Re: Fender pro 300 farting
« Reply #1 on: March 24, 2017, 11:46:39 am »
Need some clarification, do you mean with the JJ's in the problem is gone?
Offline pbman1953
« Reply #2 on: March 24, 2017, 11:49:47 am »
I really don't know if it is the JJ's. Using in pairs I couldn't get the amp to exhibit the issue, only when running all 6. I thought maybe I would see some flickering in any of  them but I saw nothing.
« Last Edit: March 24, 2017, 03:12:48 pm by pbman1953 »
« Reply #3 on: March 24, 2017, 04:25:05 pm »
You can probably use the send return to split the amp in half, then you only have 1000 things to check!
« Reply #4 on: March 24, 2017, 07:29:39 pm »
Exactly how are you splitting the pairs?
Offline Tony Bones
  • Thread Killer
« Reply #5 on: March 25, 2017, 11:33:27 am »
As it seems to be a thermal issue I would check the resistors and look for bad solder joints. With the amp on and warmed up, gently tap each resistor with a chopstick or something nonconductive. Listen for pops from the speaker.
« Reply #6 on: March 25, 2017, 05:24:21 pm »
« Last Edit: March 25, 2017, 05:35:24 pm by kagliostro »
