September 08, 2026, 12:19:04 pm
Hoffman Amps Forum image Author Topic: Correct speaker load  (Read 9881 times)
« on: March 28, 2017, 04:46:14 am »
Hi guys, I got a SS amp that I think was made in the 80's and as usual no info.
It's in sorta working order, scratchy pots.
It has had a speaker change and they have used a 4ohm 350w sub woofer.
This seems to work but I have no way of knowing if 4ohms is the correct speaker load or power rating.
It has 2/2N3773 power transistors.
I could guess that it's about 65w as the model is PS65  :dontknow:
Re: Correct speaker load
« Reply #1 on: March 28, 2017, 10:34:29 am »
IIRC most transistor amps were designed to handle speaker loads down to 2ohms.  I don't know about "optimum", without docs, it's probably trial n error.
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #2 on: March 28, 2017, 01:31:44 pm »
Here's an item that has 2n3773's and seems to imply it uses 4w impedance.
~Phil
Phil Davis
tUber Nerd =|D
Offline smackoj
« Reply #3 on: March 28, 2017, 09:21:16 pm »
I agree with Shooter; SS amps are usually stable at 4 ohms or even less. If you look at any modern SS bass amp, they always label the output with something like: "160 watts into 4 ohms"  and  "100 watts into 8 ohms"
« Reply #4 on: March 29, 2017, 04:37:45 am »
Thanks guy's, I'm sure it's a bass amp.
Sounds OK with guitar plugged in.
I'm going to replace all the pots, some have real problems.
Found a date of may 83 on the PCB.
Trying to find a cheap 100w 4 ohm speaker.
« Reply #5 on: March 29, 2017, 04:24:07 pm »
Hi guys, Found this in the schem library.
http://el34world.com/charts/Schematics/files/_Miscellaneous/HH%20MA100.pdf
Not exactly the same circuit but pretty close.
Maybe an 8ohm will drop the output to a more useable wattage.
    • Daviszone
« Reply #6 on: March 29, 2017, 06:46:18 pm »
~Phil
Weird my link didn't seem to show up and I've lost it now, /sigh I probably forgot to paste it lol.
Phil Davis
tUber Nerd =|D
« Reply #7 on: March 29, 2017, 08:58:18 pm »
All good. Thanks mate
« Reply #8 on: March 30, 2017, 02:47:36 am »
Thanks guys, converted this bass combo to guitar.
Cab cleaned up well
All original components, reverb tank at the back.
A few fancy knobs.
Passive FX loop.
Some new pots.
An Eminence 100w 8ohm seems to work well.
I wasn't sure what a Solid State Bass would sound like for guitar use, a great result.
Both channels are clear without any flabbiness or muddiness.
A very usable amplifier.
« Last Edit: March 30, 2017, 02:49:56 am by TIMBO »
Offline smackoj
« Reply #9 on: March 30, 2017, 10:23:26 pm »
That is a nice piece. I like the liberal use of shielded cable. Looks first rate. Have you tried any effects with it? Just curious.   :icon_biggrin:
« Reply #10 on: March 31, 2017, 02:39:38 am »
Not yet, will do
