September 17, 2026, 10:52:23 am
Hoffman Amps Forum image Author Topic: Matchless lightning with cathode biased El34/KT66  (Read 5910 times)
Offline Vdelli
« on: March 31, 2017, 01:27:07 am »
Hi folks,
I'm very happy with my Matchless Lightning Reverb build, I love the clean tone and also how it sound if it is pushed by pedals. You can really rock with this amp, but there could be more power when I set the amp clean an do all the drive sounds with my pedals.
So I want to build an other one. I was thinking about to use cathode biased EL34/Kt66 or something like that. I also want to build the divided by 13 FTR 37 click channel with a 5879 tube as separate channel instead of the Reverb. This could be a nice combination.
First I thought I easily use the power section of the Clubman oder Chieftain, but I read in an other thread that this schematic eats the tube for lunch.
Does somebody build something like that already?
With best regards
Re: Matchless lightning with cathode biased El34/KT66
« Reply #1 on: March 31, 2017, 08:52:56 am »
the Clubman
I built a Plexi- style pre and used a clubman pa.  Works very well, good sound.
Offline Vdelli
« Reply #2 on: March 31, 2017, 09:42:40 am »
Hi shooter,
Thanks! What can you say about the Power? Would it be loud enough for club gigs? And what's about the lifespan?
« Reply #3 on: March 31, 2017, 11:19:18 am »
Mine is running 25W into a 2X12, the guitar guys that test drove it thought it 40W and said it would work in most small venues.  I'm running the 34s at about 90% pdiss, I'd put lifespan at a year easy for a weekender.
Offline Vdelli
« Reply #4 on: April 02, 2017, 04:06:11 am »
Thank you shooter! That's sounds quite good to me. The amp would be used 3 times per week, could be ok.
